Maybe you guys can give me some advice here.
I've got a 400cid small block chevy. I tore the heads off the other day and found a puddle of oil in cylinder 8. I figured its most likely due to a leaky valve seal/worn valve guide. I still need to check the cylinder bore for out of round, excessive wear, and taper.
I pulled the valve and found alot of oil on the stem and face of both valves, although it was worst on the exhaust which had a stock umbrella style seal. I measured the stem for wear and found it to be .3719" or .3721". They must be fairly new ... the engine was "rebuilt" but recently its been smoking quite a bit and i'm tearing it apart for storage until i can throw it in a rat rod so i wanted to have a look-see to figure out what i'd need to buy to turn it into a performance engine.
Pulled the valves on cylinder 1. Measured for wear...got a stem diameter of .3409 or .3410. Again no noticeable wear, but why the difference in stem diameters!??
Second, how difficult is it to drill out the guides for bronze inserts and how difficult would it be to drill steam holes in a new cast iron head? (Set-up i will obviously have to figure out myself based on my machines, but what about tooling? Do i need carbide for the cast-iron?)
Also, does anyone have any specs or suggestions on determining whether or not i can re-use my valve springs, valves, and rocker arms? My heads are 333882 which are notorious for poor flow and cracking, so if my springs and valves are good, i wouldn't mind dropping 500 bucks for a set of new bare cast iron heads that flow better. I would then need to drill the steam holes of course.
In regards to the above, what kind of heads should i be looking for? I want the biggest engine i can and still run on low octance fuel. That being said, some options are the torquer II's from world which are pretty mild improvement over stock or the mowtown classics from world which have 200cc intake runners and 2.08"/1.6" valves. Would that be too big for the 400 to live in the low rpm band?
Thanks
Thanks
