There are a few lathe operations (e.g., cutting off and knurling) where I'd like to have cutting oil supplied more or less regularly to the cut but I don't do enough of it to invest in a commercial rig - nor do I want the mess.
So I soldered up this thing from plumbing parts found at OSH. The 'cup' at the top is a pipe-size reducer thingy (hey, I'm not a plumber) and the valve is one of those used for drinking water lines to refrigerators.
My lathe came with holes for a taper turning attachment drilled and tapped into the back of the carriage. I use one of these to secure a general purpose adaptor that accepts (among other things) an adustable holder that projects out over the area where the tool meets the work. The oiler assembly drops into this so it can be positioned exactly over the working area. The cup is filled with cutting oil and the valve adjusted to a flow rate of a drop or two a minute. Slicker than deer guts on a glass doorknob and my hands are free to attend to other things plus a lot fewer brushes get eaten by the knurling tool.
Also visible in the picture above is the chip tray secured to the traveling steady holes in the carriage. It keeps chips off the ways and makes clean up a lot easier. It can hit the headstock if the carriage moves too far to the left so I rigged a small alarm buzzer underneath to warn me when it's getting close.
The chuck wrench is also visible. It's fitted with a 'speeder' that's nothing more than a chunk of 1" aluminum, hemisphere on end, setscrewed to the wrench handle. The picture below shows how it's used. With the hemisphere bearing on the palm of the hand, moving the hand in a horizontal circle will spin those jaws in/out in a hurry.
