As part of my ongoing X3 conversions, the one that's on the bench at the moment is an early X3 to the UK with the shorter column, I think they are still sold in the US.
These machines originally come from Sieg in China or one of it satellite factories and the importer buys either to price or spec. Occasionally an importer may be able to wangle a unique deal for a while until everyone else jumps on the bandwagon and gets it. For the last two years our importer has been getting the tall column X3 and the long table X1.
When converted to ball screws all the jack shaft and bevel gears are thrown away so length of screw and mesh don't come into play. When the head is right down you still have plenty of screw left so this one has had a spacer block fitted to bring it into line with the longer column models.
Shows the 4" block with it's first coat of paint.
Rear view showing the 1-1/4" wide U shaped packing block and the Z stepper drive fitted as a unit.
No point making the block any wider as this mimics the foot print on the column onto the base.
Wick oiler fitted temporally to the side to check interference , all the slides will have these fitted.
Could be made to fit a manual machine if you mounted a new bottom bracket to the packing block and fitted a jack shaft with the bottom bevel gear on it to join up with the original screw.
The cheesy column bolts have been replaced by 140mm long Unbrako cap screws.
