Somewhere I saw a formula for shimming one jaw of a 3-jaw chuck to cut an offset. The formula was "Offset = 2/3 Shim Thickness"
The valve eccentric on my last model called for a .050" throw. I hate indicating in a 4-jaw, so I decided to give it a shot. I needed a .075 shim. What I has on hand was some 1mm brass stock. Two pieces stacked = .078"
Maybe I was just holding my mouth right, but the total run out of the piece was .101" Close enough for me. It worked out perfectly.
I'm sure it's an old trick, but one I just found. There will be no more indicating
those little eccentrics in my basement!
Rick
Rick
