Work Shop Tips (series)
  • Work Shop Tips (series)
    Hi Guys,
    I wanted to start a series of "work shop tips." Maybe some are original and you know many are not. I've been reading the HSM BBS posts for a year or so. All you folks on the BBS have helped me greatly in my endeavor to progress from "hack & slash machining" to precision work of which I can be proud. First, here's a little background on myself…
    I've been more seriously involved in metalworking as a hobby since 1995, but have worked with metal periodically since high school. When I was stationed in Germany 20 years ago, I bought a drill press and a small metal lathe (Proxxon) and those two tools helped me get established in the hobby. However, over the last 7-years, I've bought a 9X20" metal lathe, mill/drill, large drill press, metal-cutting bandsaw, oxyacetylene torch outfit, 6" belt bench sander and various woodworking tools. All this fits (barely) into our two-car garage. The house belongs to my wonderful wife, but the garage is mine. It ceased being a "garage" soon after the house was finished. It's my "shop." Trust me; no motor vehicle has ever entered its domain….except when I had to back up the truck to unload the milling machine. Lately, I've been making physics demonstration-type electric motors and assorted other scientific items. A lot of what I've made this past year was sold and I've also done some custom work for folks. I didn't get much money for the effort and quality, but that's my fault. Here's a little about my background. I retired last year from a 20-year Army career and got a new job. My background is industrial engineering in the research, development and acquisition of weapons and logistics systems. I am now working for a private company primarily engaged in providing engineering services to the Department of Defense.
    So, in that vein, here's the first of a few tips I'd like to share. I think most of you guys know a lot of these tips, but I think they're worth repeating…
    End Mill Safety. You should remove the end mill from the R-8 collet between uses. I don't always do that. When cleaning the mill, I've cut the back of my hand on the end mill a couple of times. Some folks just don't catch on right away. So, I'm not very bright, but I am lazy. To solve this problem, I found an old plastic film can and I glued a rare earth disc magnet to the outside bottom. The film can's inside ID was a little larger than the 6-flute 1" OD end mill I use frequently. With the help of the magnet, the film can stays in place…until you remove it before milling operations. I also cut some flexible plastic tubing and put it over the small end mill flutes so their edges are protected. I didn't have to do this before when the end mills were stored vertically in a wood block, but now they are lying flat in a felt-lined drawer. And yes, I should have saved the protective tubes the end mills came in.
    Next time….Shop Clean-Up (no, not all the tips are this boring).
    TIM
    You ain't got a Shaper yet?
      I am creating and modifing tools, much of it by hand. I followed Oscar's taping suggestions when I remade an arbor.
      I have made a couple of toolposts. One I made to hold a boring bar, did such a great job that it was too perfect, so I put an extra hold down bolt on it, in case I need to get the bar out.
      Jerry
        To reduce the scarring of the backs of my hands I put a plastic (vinyl?) cap over the end mill - when I remember! I'm not sure where these plastic caps come from - they seem to be end protectors for delicate or sharp cylinders. If anyone knows where to buy them, I'd like to get more in different sizes.
          Those are the kinds of things you hang on to, knowing some day they'll come in handy. And sure enough they do... about 3 or 4 days after you clean out and throw away all the clutter you've been saving, but haven't needed. You can't win!
          Lynn (Huntsville, AL)
            Hi Herb. Try vacuum caps from the auto parts store.They are rubber or plastic.The rubber ones will stretch quite a bit and they come in sizes large enough to go over a 1/2 or larger end mill.For larger sizes,caps for 5/8 or 3/4 water pump fittings are rubber also and will stretch some too.Good luck,Robert.
              Hi Al,
              No, don't have a shaper yet. Not much room left. However, if I found one of those "table top" models, I'd find a place for it, I'm sure. Herb & Robert, good idea on the vinyl caps. I'll have to look for those. The plastic tubing works well for me; it's cheap & I had a few feet on hand.
              Regards,
              TIM
              TIM
