Question about EMCO Compact 5
  • Question about EMCO Compact 5
    Few years back, I inheredted a brand new Emco Compact 5 from my father-in-law. I'm ashamed to say that it's only now that I'm dusting it off and trying to put it to good use.
    I've tried mounting the both the vise and milling table to the carriage, but I'm finding that the spacing in the mounting bolt is different. Both the vice and milling table, which are Emco original, has 25mm spacing, while the carriage mounting holes are 17mm wide.
    Anyone know why this is and how I can go about resolving this problem? Do I have to fabricate an adapter?
    Thanks.
    BTW, I'm very impressed by the quality of this machine. Everything is very smooth and tight.
    lookin at your pics..the vice seems to be upright..in the correct position?? some sort of angle plate would be needed to connect the two...it probably doesnt mount flat as you are trying...just a guess..based on my south bend version.
      Dear Sir
      to use your vise remove the set screw on the last hole
      the vise uses one counterbored hole and the one that as the set screw
      Marcel Beaudry
        Originally posted by Marcel Beaudry
        Dear Sir
        Marcel Beaudry
        Thanks you sir. That did it! I did look at the set screw, but optically it looked smaller than the other. I think it was place there so that chips wouldn't fall in to the carriage during lathe operation.
          Do not forget to put it back so the chips do not get in
          Marcel Beaudry
            In this configuration that set screw might be intended to go in the exposed hole for the same reason it's put in the original hole.
              well there...lot different than my SBL...bout 90 degrees off, learn somethin every day
              scott
                Scott, Rotate's Emco has a milling head, like a 3-in-1.
                  oooooooo
                  thank you..that helps..grin...
                  scott
