This is my first attempt to use a dovetail cutter, and I have couple of questions.
1. I'm getting quite a bit of chattering, which leave chattering marks on the inside cut. I'm using conventional milling. The only way to get around this is to reduce the feedrate such that instead of making chips I'm making powder. Is this the nature of the cutter or is my setup (EMCO Compact 5) simply not rigid enough for this kind of operation?
2. HSS dovetail cutter was wickedly sharp but after cutting only two 2" length, it no longer has that razer sharp edge. It's still sharp, but I'm wondering if this is normal?
