I'm building a low speed belt sander for sanding on the inside radius of bends that I make in tubing. The radius of the bends will range from a very gentle 6" radius down to a .250" radius. How much of a crown should I put on the wheels? Will a wheel with more of a crown result in more flexibility of the belt? If so, is the belt also more likely to come off in use?
Thanks,
Stuart
Thanks,
Stuart
