Milling on the SB-9
  • Milling on the SB-9
    I have several projects that need some milling work and no real mill in my new shop. So I got busy on a table for my SB. This is just a 3/4" piece of 1018 CRS with a lot of taped holes in it. Machined a button to fit the SB cross slide mount.
    Here's my first cut with it, in progress:
    And the finished cut:
    The vertical dimension is established with spacers. I bought a couple pieces of flat ground stock and rolls of steel shim stock. Cut out a stack of 2" and 4" long spacers. With only four sizes of stock I can get within 1 or 2 thousanths. I plan to use aluminum foil if I need finer adjustments.
    I am also working on an angle plate with a vertical X-Y slide and vise. But I needed this simple table to make some of the parts for that.
    Make it fit.
    That will do the job well. It's amazing what can be done on a lathe. I built a milling machine with a SB9.
      A great idea, could also be used to mount parts for boring.
      Would you be able to give more details re mounting to the cross slide.
        milling plate
        Give that man a cigar!I like your thinking,Paul.
        If I didn't already have a mill-drill,that would be a useful alternative.It will be better still when you get the vertical slide done.Cheap and cheerful,and it does the job.
        Hans
          I have to say I like it better than any other lathe milling attachments I've seen. I have one that I got at a yard sale and it's junk, vibrates like crazy as not enough mass. Yours look like it will work great and a low tech answer to the problem. Nice job!
            But,,, but,, mine is bigger! It also has lots of holes in it! (not shown in pic as not yet drilled). [grin]
            With fly cutter:
            Here it is milling a fan pulley for a treadmill motor.
            I also have two other such tables for different type jobs. This one is a 1 1/2" thick chunk with a variety of holes.
            Then there is the more conventional milling attachment, but a bit beefier than the commercial ones.
            I actually find I don't (didn't) use the full blown attachment very often. Nearly all the milling can be done with the tables and they are more rigid by far. Paul's is also the nicest I have seen, mine included.
              That is indeed a nice milling table. I suppose there is some limit to how wide you want to make it as it gains a lot of leverage that way. Otherwise, I have to say a design like that is better than most as it leaves some room to use real clamps.
              I really don't know the answer, so am proposing this question in hopes of a real answer. I have a mill and don't see myself doing this, but I have to wonder about the loads presented to the spindle bearings on the lathe and how they compare to normal turning loads. I know there is plenty of milling that has been done on lathes, but I would think that those with plain bearings (especially) might be prone to more wear doing this. While plain bearings are perfectly acceptable in a lathe, they are not so popular in milling machines...at least not today. A plain bearing is really a hydrodynamic bearing that relys on maintaining an oil film on which the spindle rides. Given that, there is some point at which that film is broken down by lateral forces on the spindle.
              The spindle oil used is pretty thin (intentionally) so that it will flow and create that continuous oil film. I guess the question is just how much side pressure the spindle can take before you break down this film and begin to wear the bearing material.
              Paul
              Paul Carpenter
              Mapleton, IL
                Plain bearings will take higher loads than any other sort. They are probably best suited to this type of use on a lathe. The reason is that the bearing area is extremely large compared to any other bearing type and the load per sq inch comparatively low within the bearing. The reason they aren't used in milling machines is because they have a "squish" factor.
                  While load per unit area is much smaller (assuming a good bearing to journal fit), the durability of the bearing material is also much lower. A ball in a bearing race has greater force applied to a smaller area, but the materials are quite hard while babbit material on the other hand is intentionally very soft.
                  I think the real critical issue must be that you not exceed the point at which the film breaks down or the babbit would not last long. I just didn't know what that point is in a non-pressure oiled plain bearing.
                  You can argue that internal combustion engine crank journal bearings see huge force, but their hydrodynamic bearings are fed oil under pressure. Remove that oil film maintained by pressure and they are trash in a matter of minutes.
                  Paul
                  Paul Carpenter
                  Mapleton, IL
                    Babbit relies on a matrix of soft metal that contains very hard metal crystals. It is the hard crystals that are the wear points in babbit, not the soft metal. In the case of the SB9 lathe there is no babbit, the bearings are hardened precision ground steel on cast iron. In either case it is extremely difficult to cause the bearings to make contact when rotating. It is this principle that is used in Squeeze Film Dampers that are used to stabilize and centralize the shafts of very large power turbines. The plain bearing in a lathe spindle is essentially a form of squeeze film damper and as such can take loads that would turn a point or line contact bearing to dust.
                    http://www.kmcbearings.com/products/...q_dampers.html
                    [edit]
                    BTW, if you drop oil pressure to zero in an engine it won't be the bearings that fail first. The pistons will seize in the bores long before the bearings give up.
                      On the contrary, a plain shell type bearing relies on a hydrodynamic wedge of oil to keep the bearing journal out of contact with the bearing shell. In a roller bearing equipped engine, which requires very little in the way of lubrication, yes the pistons will seize long before the bearings fail. In a plain bearing engine however, it is a matter of seconds before the bearings spin upon loss of oil flow.
                      As long as this hydrodynamic wedge remains intact there is virtually no contact between the journal and the bearing itself. This is why one of the in most common cause of bearing failure is frequent starts, at which time this wedge of oil has not yet been established. Once the flow of oil is returned to the bearing and the oil wedge is reestablished there is very little if any wear. I have seen plain type bearings that have been in non-stop service for 75 years, in an electrical power turbine, which still showed the machining marks from when it was first made.
                      It is this wedge of oil which allows the pain type shell bearing to carry enormous loads. The bearing shells in plain type bearing are quite soft so that any hard solid impurities in the lubricating oil will be embedded in the shell rather than scratch the journal causing it to wear.
                      Sorry Paul, not to hijack your thread, nice addition to your lathe.
                      I'm sure it is a lot more rigid than than an entry level mill as well.
                        However, before that happens the engine will no longer be rotating, usually.
                        I have had engines fail due to loss of oil. In all cases the piston(s) seized before the bearings. In one case I was riding a Yamaha going fast down the highway. This was a bike with oil/gas mix, no injection. I suddenly realized that the exit I wanted was right there in front of me so I had to slow down, quickly. I made the mistake of fully closing the throttle and in about two seconds the engine locked tight as the piston seized from lack of oil as the fuel was cut off. It was an interesting ride with the back tire locked solid at 60 mph. After it cooled down it started and ran fine, no apparent damage to the bearings.
                        As we are concerned about the ability of the South Bend 9 inch lathe to withstand side loads I will point out again that the plain spindle bearings are not shell bearings. They are hardened steel on cast iron.
                        I will also reiterate that babbit isn't all soft. Nickel babbitt in particular contains very hard metallic crystals in a matrix with tin. All babbitt alloys rely on the soft metal to hold the crystals of very hard metal in place. It is the hard crystals that provide the bearing surface.
                          Very nice jobs! I made a stiff angle plate that is bored to fit under the tool post and is clamped down by it. So far, I've been able to get by with it, but maybe, just maybe, there will be a good used Clausing Mill in my future!
                            Exactly my point. Unless it is a throw away weed eater engine, all two cycle engines utilize roller bearing lower ends because they operate without the benefit of a full flow oil system. Only a roller bearing could survive under those kind of conditions. Try that with a conventional lower end and the bearings would spin in the case or on the shaft within seconds. Or better yet, if you have money to throw away, and I'm sure you don't, dump the oil in your pickup and drive to town. I can guarantee that there will be plenty of oil still flying around to lube the pistons and cylinder, but not enough to save the crank and rod bearings.
                            Multi viscosity oils, swinging oil pickups, oil accumulators all point to the need to keep this fluid layer established. Without oil on the bearing it soon will have metal to metal contact. Check with some of the local engine re builders in the forestry sector and see what they say will happen to an engine that did not have the benefit of a low oil pressure shutdown system when an engine was operated at an extreme angle and was starved for oil...it won't be pistons and liners they're replacing.
                            Mind you a plain type bearing on a lathe operates under much lower pressures, but still requires lubrication to survive.The bearing on a lathe is huge in comparison to an engine bearing, it takes only a very small amount of lubricant to keep the shaft and the bearing apart. An oil impregnated bushing is a classic example of how little oil is rquired...you can't even feel the oil film. Or cast iron come to think of it, also a very good provider of lubricant, not only because of it's open and porous grain structure that retains lubricant but also because of it's ability to provide a dry graphite lubricating function. Hence it is usually a first choice for cylinder liners in industrial engines.
                            I will also reiterate that babbitt isn't all soft. Nickel babbitt in particular contains very hard metallic crystals in a matrix with tin. All babbitt alloys rely on the soft metal to hold the crystals of very hard metal in place. It is the hard crystals that provide the bearing surface.
                            I won't argue the fact that the material and function of a straight babbitt lathe bearing is vastly different than say a tri metal engine bearing whose first layer next to the crank journal is babbitt, followed by copper, and then a steel backing. the main function of the babbitt layer is particulate embedability, not lubrication.
                              I am quite sure the Yammer didn't have a roller bearing crank. Those were pretty primitive bikes back then in the sixties.
                              I'm sorry, but experience tells me that the bearings are much less sensitive to oil pressure loss than the cylinders. There is still oil in the system and bearings and they don't suddenly wipe dry like the cylinders do. When an engine seizes while running it is because of lack of oil to the cylinders, not trashed bearings. An engine will still turn with spun bearings. Had a Suburban that did that once. It still ran but made one hell of a noise. But when the oil pump broke on my Morris Minor the engine stuck tight. Had no warning because it had no gauges or idiot lights.
                              I'm not saying the bearings won't be damaged. They probably will. They won't be the immediate cause of the failure of the engine to operate in most cases. Stuck pistons will.
                              No, the main function of the babbitt is to act as a bearing. The copper liner is a compatible material that will bond to the babbitt as well as the steel shell. The function of those layers is strictly to support the babbitt layer. Without the layer of babbitt there is no bearing. It's all about lubrication.
