If you make a spindle/axle for a bearing how tight should the fit be? Slide on our press fit? Say a 5/8 dia.
Bearing fit
About .0001" to .0004" interference, depending on bearing design, journal surface finish, load, speed, lube, service factor.Free software for calculating bolt circles and similar: Click Here
"wheel bearing light duty use"
sorry Tim, you're gonna have to a lot more explicit if you want a meaningful answer.
"light duty" for a garden wheelbarrow or
"light duty" for an occasional run at Bonneville on a 1920 Indian Scout?
Pardon me if I sound facetious, I've heard sillier questions asked by engineers.Just got my head together
now my body's falling apart
Originally posted by timhThis would be for a wheel bearing light duty use.
It may be a bit tighter if its on a boat trailer that goes down the road at 65 MPH.
If the spindle is stationary, as in an automobile front wheel bearing, The spindle should be loose sliding fit, and the OD should be a press fit.
If the spindle turns, then it is opposite, with the spindle being a press fit, and the OD a sliding fit.
Rich
"Loose" is .0005 clearance
"Press" is .0003 interferanceGreen Bay, WI
While the "Expert" engineers will spout the fact that bearings all have a specific fit per use, I have to grin, because I know from experience that in reality, more often than not, all those extremely precise specs get amazingly forgotten while in the manufacturing mode.
Except for the bearings themselves.
