I have several good sized shafts of stainless steel that were given to me by Tryp when he moved east. I would like to narrow down what sort of SS they are. I have done a few tests but need an interpretation of certain results.
The material is very non-magnetic. However, it exhibits an anomalous response to work hardening. I have beaten the daylights out of one end of a test sample and the beaten end is much less magnetic than the unworked end. The is the opposite of what is expected for 300 series austenitic stainless steel, which is likely the alloy group of this material. Work hardening of 300 series SS normally produces an increase in magnetic attraction, not a decrease.
The material machines and cuts beautifully with a fine finish using HSS or carbide tooling. It cuts very easily with a horizontal bandsaw leaving a very clean cut and with no sign of work hardening
Bandsaw cut: Please ignore rust stains, they are just contamination of the surface by contact with rusty mild steel. Shaft is about 1.5" OD.
One end of the shaft is was drilled and tapped leaving a relatively thin wall. I used a small hand sledge as seen in the background to hammer it with a dozen heavy blows. Instead of plastic deformation the material exhibits brittle failure with very little plastic yield.
Example 1:
Example 2:
Any ideas what alloy and/or chemical exposure would produce such a result?
Example 1:
Example 2:
