While you're ID ing stuff Evan, what was the shaft you asked about?
Identifying material
There are several basic plastic families that are relatitively easy to isentify. Then there are composition withing each family based on fillers, mixtures, blends with other families, and so on. It's all very complex if you absolutely positively have to determine what is what.
Generally a burn test of a small sample will get you in the ball park.
