Setting the sine bar over 45 degrees is usually done for compound angle fixturing, such as setting a rotary table on top of it to bore or grind holes in a perimeter, at an angle. In that application, small errors can make a difference in the first thing to be attached to the table itself, as now you've starting to stack objects and accumulating error.
It's also done in some inspection applications, where you want to get the specific angle between some feature and another without interpolating it from other features (and thereby increasing the error of the measurement).
And unfortunately, there can be more error in the method detailed in fig. 33 than is suggested by that text, by nature of a somewhat awkward setup.
