Enco spindle thread
  • Enco spindle thread
    I would appreciate some help. I have an Enco 12" X 36" bench lathe, model #110-2079. There is a thread cut into the ID of the left end of the spindle (non chuck end). I can't get any of my gages to fit into it well. I called Enco and they say it's a thread put into the spindle for mfg. purposes.
    They get regular calls about this but cannot tell me what thread it is. They do say that gun smiths use this thread for their spiders. I have no idea what a spider is but was hoping a gun smith on this forum might have one of these lathes and knows what this thread diameter and pitch might be.
    The spindle bore is 38mm so I would assume the major diameter will be 40MM unless it's a complete Bas***rd.
    Vern
    Vern, that's a good question. I'd like to know too.
    I have a Hare & Forbes AL-330A which I'm sure is the same machine.
    Chris
    Brisbane Australia.
      I am guessing here, but have you tried Metric thread gauges? Gary P. Hansen
      In memory of Marine Engineer Paul Miller who gave his life for his country 7-19-2010 Helmand Province, Afghanistan. Freedom is not free, it is paid for with blood.
        Metric
        Deleted/edited-out
          I tried metric as well as Whitworth gages, didn't try imperial, never thought it could possible be imperial. The guy at Enco said about half the minor diameter of the thread is removed as part of the mfg. process. Even so, some gage should line up with the remaining thread depths. His suggestion was to try threads until I find one that works.
          My machine was definitely built in china, not the Republic of. I can probably find other identifying markings if someone thinks that have a clone just under a different name.
          Thanks for the efforts to date.
          Vern
            If you can thread something onto it, you can make a "spider" which is a tube with 4 screws in it that allow holding and centering something extending thru the spindle. Like a 4 jaw, sort of, with the screws as the "jaws".
            I have seen them called "catheads", and "pot chucks" also.
            Much nicer if the screw threads were on the OD, although you might use them for a self-ejecting drawbar, as well.
            No clue about the thread, but is is almost certainly a standard pitch, although probably a non-standard diameter.
              Vern,
              Mine is a horrible fright 12 x 36.
              Spindle plug I made for mine, 1.625" OD.
              16 T.P.I.
              Les H.
              The Impossible Takes Just A Little Bit Longer!
                Hare and Forbes
                I rang Hare and Forbes and they went off to measure the thread and call me back.
                They said that it is not a Metric thread and has the same TPI as 3/8" BSW (British Standard Whitworth) 55 degree pitch 16 TPI.
                In otherwords, a Mongrel thread.
                Rgds
                Michael
                Australia
                  The 16 TPI Whitworth is a pretty good match, now I have to find a 55 degree threading tool. Why would our Asian friends use a Whitworth thread? To further complicate the issue the forward/reverse switch went toes up this morning.
                  Thanks for all the help.
                  Vern
                    16 TPI = 1/16" pitch
                    could it be 1.5mm pitch which is very close to .060"????????????
                    Just wondering of all the possibilities.
                    Remember Tiawan used to be British.
                    My Tiawan milldrill is a mixture of metric, whitworth and American fasteners.
                    Graeme
                      Taiwan?
                      "Remember Tiawan used to be British."
                      Are you thinking of Hong Kong?
                      Rgds
                      Michael
                      Australia
                        Vern
                        I have a Grizzly basically the same. As stated in other posts a spider works there but it will also be used for a collet lever closer. The adapter threads on it. May be for other stuff but these 2 for sure.
                        Life Is Grand
                          Spider
                          Can't wait forever for the Spider pictures!
                          This will have to do in the interim.
                          Rgds
                          Michael
                          Australia
                            Yours? What did you name him, Harry?
                              Ouch
                              Deleted/edited-out
