shop built mill
  • shop built mill
    Hello Can some post a link to the shop built milling machine that uses an
    inline engine block for the base/frame. Had it saved, now lost.
    Thanks chiphead42
    chiphead42
    http://opensourcemachine.org/node/2
      Not again,They are a POS. You do not live in a 3rd world country, or maybe you do.
        Re shop built mill
        rgbai Thanks for the reply. but this is not the one I'm looking for. there was
        one that is a horozontal mill built into a 4 or 6 cyl. engine block. Can"t find it or remember where I saw it.
        IOWOLF WE"re not living in the 3rd world, but we're not as far from it as we have been in the past. Still searching Thanks chiphead4
        chiphead42
          you must mean george ewans engine mill from feb/march 2002 machinists
          workshop.
          http://www.freewebs.com/cochranearea...ers/gaewen.htm
            Here is a thread discussing the spindle:
            http://bbs.homeshopmachinist.net/showthread.php?t=11268
              I know it as the multimachine.
              http://groups.yahoo.com/group/multimachine/
                I don't see an engine block in that one,perhaps too much other crap.
                  Re shop built mill
                  That's the one, I think I have enough odds & ends to put one together.
                  Thanks guys. chiphead42
                  chiphead42
                    Post pictures as you go along. I find it is an interesting machine.
                      Multi-machines & Engine block mills...
                      Chiphead;
                      OK here is a brief description of what I am doing & what I found out....
                      Back about 2002, one of the early HSM members, G A Ewen, built a small horizontal milling machine out of a 4 cyclinder engine block, a small Busy Bee milling (x-y) table and some old shaper parts. The article is in the Feb./Mar 2002 edition of Machinists Workshop...It seemed to work out OK for his needs.
                      As Iowolf & others have said, there is this multi-machine thing that is similar, but very crude in that it uses a jack to raise/ lower the table, who knows what as spindle bearings etc. but for construction on the cheap in an area with limited resources, it may be one idea....
                      I started construction of an "engine mill" a little over a year ago, since I needed a small horizontal mill and live in an area where they aren't popular. I see the odd tiny hand mill and lots of Kearney & Treckers, but I can't move them....I am now about 2/3 finished my version. I used a dead 4 cyl. block from a Ford Ranger (the ubiquitous Pinto engine), a medium quality x-y table from Bell Machinery, parts from another x-y table for the knee elevation, machined the spindle as per G A Ewens article, and some of the left over engine parts for the over-arm etc. My knee is a weldment and I built a base on casters to hide the drive & motor and provide a bit of storage.
                      Since this was designed to be a companion to my Atlas 618, I bored the spindle Morse taper 2, since I have a bunch of milling arbours etc. for the Atlas and that is the headstock taper.....
                      If I didn't already have the dead Ranger engine, I would have probably gone for a 6 cyl block like a 300 cid Ford or 292 GM. That way you could have the motor on top, over arm in the 1 st. cylinder, etc. and arrived at a design not unlike the Tom Senior horizontal mill. Get a good quality x-y table and a bit of good design & careful machining for the knee weldment and spindle and you could have a fun little horizontal mill.
                      As far as mine goes, I'm into it for about $ 300.00 Cdn. including the spindle bearings, a piece of 2 1/2 in bar stock for the over arm and the x-y table. I built this partly just as an exercise to prove it could be done and because I couldn't find a small but still useful sized horizontal mill for sale locally for a reasonable price. (Tom Seniors, Rockwells (I have a vert.) and Clausings go for gold-plated prices up here...) I also had several free motors and lots of pulleys & scrap on hand.
                      To do a good job on one, you will need the use of a 10 in. or larger lathe and a milling machine, drill press and ideally a surface grinder....You could do all the machining on a lathe that is large enough to swing your knee weldment on it's face plate...
                      I'm looking forward to getting this thing finally assembled ( been a few test fit-ups so far), aligned and trying some gear cutting with it. (That was the original reason to get/ build a horizontal mill.)
                      Hope that helps....
                      Rick
                        i like the mother of all cord saws on that site...nice stuff, nice little mill also..prob better made than that little atlas horz. mill i had years ago
                        scott
