taper reamer
  • taper reamer
    Help!! I need information about taper reamer for ball joints and tie rod ends. Need to knowtaper per inch or foot or where to purchase such items. Thanks JIM
    jim
    Typically 1.5" per foot for most tie rod ends and ball joints on vehicles from the big three, although you might find something different. Measure what you have if you aren't sure. Look for a right hand cut with straight or left hand flutes so it is not overly aggressive.
    I like these:http://www.speedwaymotors.com/p/2918...?itemNo=reamer
      Look for XKUT on ebay. Very reasonable for low use grade (won't hold up to production, but nicely made for HSM) taper reamers. I've got one that's been used several times with great results.
      Russ
      Master Floor Sweeper
        Check the archives, for more answers.
        This Question pops up now and then.
