I have 12 bearing blocks to do out of rectangular stock. These need to be identical and are offset in the bar stock.
I have marked them out with a vernier hight gauge and spotted them with an optical punch so these are spot on. The first one I setup with a sticky pin and dial gauge. Didn't take long but I wanted to speed it up a bit so I went into the shop tonight and made this centre finder up.
Not saying this is unique, not much is, but it's something I cobbled up in about 30 minutes.
Pic at:-
http://homepage.ntlworld.com/stevens...e%20finder.jpg
The body is a bit of hex bar about 6" long in total. No reason for the hex, it could be round but I had three design changes between the saw and the lathe
About 1 1/4" is turned down one end to about 1/2 so it can fit in the tailstock chuck. This part is drilled and reamed 1/8" for 1 1/2"
It's then turned round and drilled to meet the 1/8" hole to about 1/2" diameter. This is only clearance so it doesn't matter about size.
Next a bit of 1/4" plate was welded on to form an ear for a clock to bolt to.
Last bit is a piece of 1/8" drill rod or silver steel with one pointed end and the opposite end held in the reamed hole with a small grub screw.
Method of operation:
Put atachment in chuck, offer up to the centre punched mark and rotate the lathe by hand. Any run out will be shown on the clock. Adjust the 4 jaw as per normal using only one pair of jaws at a time.
Got the second one setup in just less than 30 seconds.
I make no apologies for the state of the attachment. This was a rush job and needs play a greater part than shiny surfaces. It works and it's quick.
Feel free to make or modify as it suits.
John S.
Pic at:-
John S.
