Cut 1 x 8 thread
  • Cut 1 x 8 thread
    Well, I got my dies and handles in to cut this thread. I have nothing that will hold the arbor without rotating. Should I give up in this method and cut the threads with my lathe?
    Jerry
    Partially cut them with the lathe and use the die just to put the finishing touches on the threads.
      Yeah -- I think the best approach for "big" threads is to help things along by screwcutting in the lathe first, then finish to final form with a die if you have one. (Or tap, if an internal thread.) I've done 1 1/2 - 8 threads for a chuck backplate that way. I don't have a clue how I'd ever turn a 1 1/2 - 8 tap otherwise. Cutting to within about 5 thou in the lathe, then running the tap in, makes it easy.
      Aside from reducing the force required by about a gazilliion percent, it also gives much greater assurance that the resulting thread will be square to the work.
        Of all the turning operations that can be done on a lathe, thread cutting is my favorite.
        As far as I know it's the only way to cut a perfect thread. A skill worth learning. Practice, Practice, Practice.
          I have forgotten what you wanted to thread. If it is an Atlas backplate, I would not have bothered with the tap.
          Cast iron is nice cutting, and if you have a problem, you can always turn the thing by hand the last turn or so to avoid running into an invisible internal shoulder etc (or just mark the boring bar!!!)
          Since you have the tap, might as well use it, but I think that thread cutting on the lathe is way over-rated as to difficulty of learning. In reality it is easy to grasp and not hard to do.
            <font face="Verdana, Arial" size="2">Originally posted by G.A. Ewen:
            </font>
            I agree, threading on a lathe is my favorite operation too. I think that threading is probably the most important function of an engine lathe. Remember, a lathe will cut a thread of any pitch on any diameter within the capability of the specific machine. The threads cut on the lathe are concentric and square to the axis of the work piece, and are created in easy progressive steps. Try tapping a large hole in a small work piece, while trying to hold the piece against rotation, apply enough torque to the tap, and try and get the thread started straight all at the same time. You soon realize the value of the screwcutting lathe!
            THAT OLD GANG 'O MINE
              Agree with all above. Lathe Threading is:
              1) Important to learn.
              2) Lotsa fun.
              3) Not at all hard to learn or do.
              4) Good for your ego and self-esteem
              5) Makes you appear sexy to opposite gender
              6) Other benefits too numerous to mention
              Lynn (Huntsville, AL)
                lynnl,
                Regarding point 5) above ~ please elaborate further. Do I have to be proficient in left hand as well as right hand threads??
                RR
                  RR
                  Dang! Beat me to it...
                    A man that knows how to thread proficiently, be it right hand or left, is always sexy.
                      HUH? I am so confused.
                        <font face="Verdana, Arial" size="2">Originally posted by Ragarsed Raglan:
                        lynnl,
                        RR
                        </font>
                        Not unles you are a pig
                        John S.
                          I am also lost is this some kind of sexual innuendo Alistair ps and on a Sunday too
                            RR - I think it kinda depends on which gender one wishes to appeal to. I guess a multi-talented person's appeal would be universal.
                            ...or maybe Kitcat has it nailed down! (BTW, I'd think the same would hold true for a women. )
                              Thanks lynnl, for your last sentence. Didn't mean to cause confusion, just putting in my opinion.
