VFD REliance SP500
  • VFD REliance SP500
    I was working on my New surface grindr equipped with the above mentioned VFD. When i start grinding (cleaning up my new mag chuck) the motor would shut down under the slightest load. How do you determine the max amperage the things set to so i can readjust it for what it needs to run the three phase one horsepower electric motor, I run it from 220 single phase. It works great but under the slightest load clips off. Thanx Mike
    This procedure is a supplement to and to be used in conjunction with the Installation and Operation Manual for the SP500 Manual for the SP500 AC Controller I/M D2–3304–1. The procedure is meant to explain and condense the installation and operation manual to the basic and most used applications.
    | Hardware | Power Off | Power On | | Software | Parameter List |
    Hardware
    Drive Protection
    Input Voltage and Motor wiring should be sized in accordance with NEC/CEC and all other local codes. Input fuses should be provided to meet NEC/CEC and all other local codes. Suggested protection is a fused disconnect as described in Section 3.7 of the I/M.
    Wiring
    Three–phase incoming AC shall be wired to terminals R, S and T (as shown in figures 1 & 2). Single–phase AC shall be wired to terminals R and S. AC input wiring, motor wiring and control wiring should be run in separate conduits. Drive chassis ground and motor frame ground wires should be tied to earth ground.
    Figure 1. Power Term 1SU1XXXX and 2SUXXX Controllers
    Figure 2. Power Term 1SU4XXXX and 1SU5XXX Controllers
    Power Off
    Record drive and motor nameplate information including RPM, FLA and HP. Check the drive and motor wiring, with an ohmeter on the highest scale, for grounds. The ohmeter should read in the Megaohm range or totally open. Check that the incoming AC power is appropriate for the voltage as stated on the nameplate of the drive.
    Power On
    With motor not wired to the drive, apply power. Drive will go through its own software self–testing procedure for approximately 5 seconds, and then display on the keypad 0.00. At this point you can press the start key on the keypad.
    If FL is displayed on the keypad LEDs, check that there is either a wire or motor thermostat connected between terminals 10, 11 (as shown in figure 3).
    WARNING
    DRIVE HAS DC BUS STORAGE CAPACITORS. WITH POWER APPLIED +/- TERMINALS SHOULD=APPROXIMATELY 325 VDC FOR 230 VAC OR 650 VDC FOR 460 VAC DRIVE (AS SHOWN IN FIGURES 1 AND2).
    Turn off power, allow bus storage capacitors to discharge by letting drive sit without power for 5 minutes or check DC voltage on +/- terminals. Check motor wiring for the appropriate voltage. Wire motor to U, V and W (as per figure 1 and 2.)
    Figure 3. Regulator Terminal Strip
    Running the Drive
    With motor disconnected from the mechanical load, reapply power and run the drive. With the drive in the local mode (from the keypad), remote led off, press start key and observe motor rotation. If motor rotation is incorrect, turn off power and let bus caps discharge as above, change any two motor leads (at U, V and W).
    Run motor up and down the speed range by pressing up/down arrow keys. Connect motor to mechanical load and run drive throughout speed range. Check monitor rpm, percentage load and voltage using mode/enter key. Check calculation in software section for function F–14 motor thermal overload.
    Quick start–up is complete.
    If the application requires remote start/stop or analog speed reference read Section 5.0 Adjusting the Values of Drive Functions and Typical Wiring Diagrams, Section 3.0 Installation and Wiring.
    Software
    For most local applications default values are acceptable as listed on the attached parameter list.
    To Change Parameters
    * Press stop/reset key to stop the drive.
    * Press mode/enter key, Program LED should light.
    * Press up/down arrow key until desired function.
    * Press mode/enter button which display value within function.
    * Use up/down keys to change parameter content.
    * Press mode/enter button.
    * Press stop/reset button to exit programming mode.
    To View and Clear Error Log
    * Press mode/enter button to enter program mode.
    * Use down arrow key until Err is displayed.
    * Press mode/enter keys to scroll through errors.
    * Press stop/reset key to clear faults.
    Possible Faults
    HU D–C high bus voltage condition
    LU D–C low bus voltage condition
    OL Electronic thermal overload
    OH Controller high temperature
    OC Overcurrent, short circuit protection
    FL External function loss
    Important Parameters to Check
    F–00 Control source select (0=local, 1=remote control–terminal speed reference, 2=remote start/stop with keypad speed reference, 3=remote tb start/stop with tb multi–speed presets)
    F–01 Accel time 0.5-30 seconds
    F–02 Decel time 0.5-30 seconds
    F–03 Minimum speed
    F–04 Maximum speed
    F–05 Current Limit
    F–08 RPM scaling at abase speed (whatever you want display to read when drive reaches F–07)
    F–14 Elect thermal overload = (motor overload fla/drive output fla) x 100
    Monitoring Speed, Current, Voltage, Percent Speed Reference
    While drive is running press mode/enter key until desired LED is lit. RPM LED displays output speed scaled by whatever is in function F–08. Percentage Load LED displays percentage of controller fl output amps. Voltage LED displays motor output voltage. With F–13 set to on, all these LED’s lit, displays remote reference percentage
    For Remote Start/Stop via Terminal Board with Speed Pot Reference
    F-00=1
    NOTES
    1. J6 Speed Ref
    Pins 1–2 0–10 VDC
    Pins 2–3 0–20 mA
    2. Output 0–10 VDC
    Volts, RPM or Percent Load
    Depending On Mode On
    Mode/Enter Display
    3. Relay Configurable
    Function F09
    0 Controller Running
    1 IET Active
    2 Drive at Speed
    4. Connection Must Be
    Made To Run
    For Multi–Speed Application via Terminal Board with Remote
    Analog Ref and 3 Multi–Speed Presets
    F–00=3 presets are set with functions F–23, F–24 and F–25 as
    per table in note 5.
    NOTES
    1. Open = Stopped
    Closed = IET Reset/Start
    2. Output 0–10 VDC
    Mode/Enter Display
    Function F09
    1 IET Active
    2 Drive at Speed
    Made To Run
    For Remote Start/Stop via Terminal Board with Speed Pot Reference.
    F–00=1
    NOTES
    1. J6 Speed Ref
    Pins 1–2 0–10 VDC
    Pins 2–3 0–20 mA
    2. Output 0–10 VDC
    Mode/Enter Display
    Function F09
    1 IET Active
    2 Drive at Speed
    Made To Run
    SP500 I/M D2–3304–1 Parameter List
    Function
    Description
    Range
    F–00
    CONTROL SOURCE SELECT 0 = LOCAL
    1 = REMOTE TB CONTROLS ANA REF
    2 = REMOTE TB CONTROLS LOCAL REF
    3 = REMOTE TB CONTROLS, MULTI SPD
    PRESETS
    0
    F–01
    ACCEL RATE 0.5-30 SECONDS
    5.0
    F–02
    DECEL RATE 0.5-30 SECONDS
    5.0
    F–03
    MINIMUM SPEED 0.5-30 Hz
    5.0
    F–04
    MAXIMUM SPEED 30-240 Hz
    60
    F–05
    CURRENT LIMIT 10-150 PERCENT
    150
    F–06
    MAN TORQUE BST 2-10
    2
    F–07
    VOLTZ/HERTZ 3-240 Hz
    60
    F–08
    RPM [email protected] 10-9999
    1750
    F–09
    CONFIG OUTPUT RELAY 0=CONTROLLER RUNNING
    1=IET ACTIVE
    2=DRIVE AT SPEED
    0
    F–10
    CARRIER FREQ 4,6,8 kHz
    4
    F–11
    REMOTE REF GAIN 60-100%
    100
    F–12
    REMOTE REF OFFSET 0-40%
    0
    F–13
    PER SEL SPD REF ON, OFF ON=ENABLED
    OFF
    F–14
    ELECTR THERM OVLD 20-100%
    100
    F–15
    ELEC THERM ENABLE OFF, ON
    ON
    F–16
    COAST STOP ENABLE OFF, ON
    ON
    F–17
    REVERSE DISABLE OFF, ON
    OFF
    F–18
    RPM SETPOINT ENABLE OFF, ON
    OFF
    F–19
    POWER–UP START ENAB OFF, ON
    OFF
    F–20
    PASSWORD LOCKOUT OFF, ON
    OFF
    F–21
    AVOIDANCE FREQ MIN–MAX FREQ
    5
    F–22
    AVOIDANCE BAND 0-10.0 (HZ)
    0.0
    F–23
    MULTI–SPD PRESET MIN–MAX FREQ
    20
    F–24
    MULTI–SPD PRESET 2 MIN–MAX FREQ
    20
    F–25
    MULTI–SPD PRESET 3 MIN–MAX FREQ
    20
    F–26
    AUTO RESTART NUMBER
    ATTEMPTS 0-10
    RESETTABLE FAULTS
    OVERTEMP - OT
    OVERCURRENT - OC
    HIGH BUS - HU
    LOW BUS - LU
    THERMAL OVERLOAD - OL
    0
    F–27
    AUTO RESTART RETRY WAIT TIME 1-30 SECONDS
    1.0
    F–28
    CONTROL VOLTAGE INPUT VOLTAGE DEPENDENT
    F–49
    SOFTWARE VERSION
    ERR
    ERROR LOG
    Reliance Company, 1995.
    Note: This material is not intended to provide operational instructions.
    Appropriate Reliance Industrial Company instruction manuals
    and precautions should be studied prior to installation, operation, or
    maintenance of equipment.
    Excuse me, I farted.
      http://www.reliance.com/prodserv/standriv/d2909.htm
        vfd
        Hey Mike,go back and read the manual over again.I,ve been using a bronco unit for over 8 yrs.and I have a receptacle on it so I can plug in a bridgeport,saw or lathe. (One at atime, Up to 1hp.) On the same unit.... Your unit sounds like it should have it,s own forum name (Talks good but has 15 reasons not to work.) Best of Luck,Bert
          OK..
          Put the amperage off the motor plate into the inverter. Make sure the motor is tapped for 220 volts ok? That'd make it weak and stop. erratic at slow speeds. Find the motor amps percentage of inverter output amps and enter that as F05 percent inverter setting? ok? example, 100%= full inverter output amps for trip.
          David
            Wow
            Thanx Dave Mike
