Jig for Cuttermaster - more pictures
  • Jig for Cuttermaster - more pictures
    Here are a couple of shots, almost done with phase 1. Phase 2, will be adding the cross slide with a bearing under it, in place of the current tool holder, to knash end mills and sharpen the radius'. Phase 3, is to make riser blocks for the motor, so I can get under the wheel to sharpen horizontal type cutters. Phase 4 will be to make a couple of centers set up on another plate, so I can grind between centers and swivel the jig for tapers. I am going to be at this project for a while with these expectations.
    "Just build it and be done"
    Great work...
    Thats fine work, can you share some details about which parts you made, what you scrounged, etc?
    James Kilroy
      Please see the other cuttermaster post, I combined the two, as I should have in the first place. Thanks for looking and the comments. Jay
