yf,
The use of a chop saw to cut circles is a great idea. I can imagine that making a pretty round disk with a pretty nice edge. Probably a noisy, dirty job but effective and a cleaner edge than using a torch. I have cut nice circles with an acetylene torch equipped with a circle cutting attachment that you can buy at a welding supply shop. It is a steel rod with a ring and set screw on one end to hole the torch and an adjustable point on the other end to fit in a punch mark or hole on the other end. With what is referred to as a "drag tip" on your torch you can cut nice circles. The drag tip has the pre-heat holes in a a straight line and it has a small wheel to allow the tip to ride on the material being cut. Works well on mild steel plate with practice.
With regard to jig sawing thin metal l would sandwich it between plywood. Cuts down the noise and vibration, guides the jigsaw blade and makes a cut with less of a burr. Use some spots of spray glue to hold the plywood to the sheet metal. Notice I said "spots" not the whole surface or you will have a lot of trouble getting the stack apart.
