Starrett micrometer head
  • Starrett micrometer head
    I bought this on eBay for $27 (including shipping). This is the auction photo, since it hasn't arrived yet. I'll be using it in a fixture to measure thermal expansion of materials. It reads 0.0001" without a vernier, so seems like a lot of precision for the money.
    Allan Ostling
    Phoenix, Arizona
    Wow, Now you just need a use for it.
      I ebay'd mine for something like $20.00. Then the guy tried to beat me out of the shipping fee. Mine was everybit as nice as that one but it would have seen no use in my crude shop.
        Why are you measuring the thermal expansion of materials, if I may ask? Have you invented unobtanium or similar which has not yet been characterized? Also, it seems to me that for measuring such small differences a non contact optical method such as interferometry would be more suitable.
        There are also other optical methods that will work. Optical systems are a particular interest of mine. You might find this interesting:
        http://vts.bc.ca/metalshop/laser/flattest.htm
          Evan,
          Not exactly, but I do need to know the C.T.E. of some organics, like bamboo, wood, etc., not typically published.
          Also, I intend to use this micrometer head as an actuator, used in experiments in lieu of an actual material undergoing thermal expansion. I'll have to be careful doing this, as I'm sure the micrometer head was not designed as a "jack" subjected to axial loading.
          On another topic: I'm inspired by your turning lens barrels from black plastic pipe. One of these days I'd like to make a pair of periscopic binoculars, like those used to look over the edge of trenches during WWI. With the arms swung out these greatly increase the baseline, increasing the stereoscopic effect in direct proportion to the separation. I used to do stereo photography, and became mesmerized by hyperstereo views of distant scenes (the Grand Canyon, cityscapes, etc.).
          Allan Ostling
          Phoenix, Arizona
            It'll be fine.
            I've been using some of those adjustable Vernier spanners for years and they still grip on rusty old nuts...
            Peter
              I have made other optical instruments with black plastic pipe. There are many fittings that can be easily modified to different purposes.
              I used to do stereo photography,...
              A favorite of mine too. Here is a crossed eye stereogram of the frame for the spiral staircase I built.
                Evan,
                Now that is what I call a staircase!
                I can instantly fuse parallel images too, so feel free to post 'em anytime.
                Allan Ostling
                Phoenix, Arizona
                  That's right at the limit of what I can parallel stare at comfortably. With crossed eyes it pops right in. How did you shoot that?
                    I shot that hand held with a separation just slightly greater than usual interocular separation. The key is to use the same point of aim for both shots, not just move the camera over a few inches. Crossed eye is usually a lot easier for most people. Parallel generally requires that the center of the two images be no further apart than the viewers interocular distance. Since I have no control over the absolute display size each person is using parallel isn't a good idea. I might try some anaglyphs though. Get out the red/green glasses.
                      Could a script be devised which would sense the display size, and scale posted parallel stereo images to 60-65mm between homologous points?
                      Allan Ostling
                      Phoenix, Arizona
                        Not possible. Information regarding physical size of the display isn't available to the system. It has never been a part of the "Plug 'n Play" specification for the data transfered to the computer on request.
                        This is all that my laptop knows about it's own screen and that is more than many computers.
                          OK when do we get the blue and red cheap glasses?
                            I got mine with the Sports Illustrated 3D Swimsuit Issue a few years back. They work extremely well. Those things could put someone's eye out (not the glasses).
                              Here's another.
                              And here is an anaglyph of the same scene. I have altered the parallax to make the standing piece seem to stick out of the screen a couple of inches.
                              (red on right eye)
