Select machine Tool lathe
  • Select machine Tool lathe
    Hello,
    I bought a Select machine tool lathe a while back and I'm getting ready to get it running again. I am looking for some help as it is missing a few parts. This lathe appears to be a clone of the Jet/Enco 1024/1036. I've had no luck finding parts so I'm hoping someone who has one of these and can take some measurements. I'm missing the step pulleys for the motor. Can anyone tell me what size they should be? Also I'm missing the banjo bracket and stud gear that connects the spindle to the gearbox. I figure I can make the banjo but I'm need to know how many teeth the gear has. Any help would be appreciated.
    thanks
    rodger
    pics can be found here:
    http://i206.photobucket.com/albums/b...electlathe.jpg
    http://i206.photobucket.com/albums/b...oollathe_2.jpg
    Select Machine Tool Co Lathe
    Just wondering did you get your lathe working or did you part it out.
    I have one and am in need of the reverse tumbler. Let me know if you have found a supplier for the parts. Thanks Rick
