Harbor Freight 12 x 36
  • Harbor Freight 12 x 36
    Harbor Freight's 12 x 36 lathe just went on sale, and I'm thinking of buying one. I don't see a collet attachment listed for it. Does anyone know if one is available for it. Such as the Grizzly collet?
    Thanks
    Doesn't that lathe have a D1-4 chuck mount?
    There are some available (Bison I belive), but they are expensive. Oddly enough, Smithy sells an unusual collet chuck for your application for only $115. I have one and it works fine, quite accurate.
    Try this link:
    http://www.smithy.com/ecom/detail.as...sc=LATHE+SETUP
    Edit: Look at the 67-024, $115
    [This message has been edited by Joel (edited 05-10-2003).]
      You can buy the one from Smithy or you can build the one described in the Dec/Jan 2003 issue of Machininist's Workshop for half that. It is a good learning project that can be made almost entirely with your new lathe.
