Making a Lathe Drive Cener
  • Making a Lathe Drive Cener
    A number of folks have asked me about the "drive center" I used to turn the bearings for the MLA filing machine kit, so I posted an article about it on my Web site, along with another about the sine fixture I use to establish accurate taper angles on my lathe.
    Making the Drive Center:
    Making the Sine Fixture:
    Frank Ford
    FRETS.COM
    Gryphon Stringed Instruments
    My Home Shop Pages
    Frank Ford
    HomeShopTech
    Frank, Couldn't you have put a "fairly strong" spring in behind each
    of the drive pins to accomodate any irregularities on the end of the
    part????? In effect make then float just as the center does.
    ...lew...
      You make me feel SO inept, but I love reading your articles. Does that mean I'm masochistic? Seriously though, very fine work on both. You guys that post these very nice projects inspire me to do better work. Thank you!
      I really like the drive center, and the sine bar fixture too. Unfortunately, my compound, being "old iron aesthetic" with "as cast" rounded top and non-reference flat side is not suitable for such. I suppose I might be able to make it work by scraping in the side and changing the design, but the DTI and exemplar will have to suffice for the near future.
      Russ
      Master Floor Sweeper
        something like this would be xcellent for woodturning as a drive dog well done nice workmanship.Alistair
          Briiliant
          Frank,
          In one of the Bedside Readers, Guy Lautard has an article on using a sine fixture for setting the compound angle (or tail stock offset) but somehow it never made sense to me. He mounted a plate with a spigot on it in the chuck but the explanation never made sense to me. Your method is very clear and concise.
          Like BadDog My SB9 with it's "old iron curved aesthetic" will need a bit of adapting to make this work. Perhaps a couple of well place alignment pin holes or a side trued up will do. Or better yet a rectangular boss on the bottom of and "L" shaped piece (you made a "Z" shape piece) sized to be a close fit in the slot inthe compound.
          Edit: A square boss would be better so you could get 90 degree steps in rotation if needed
          The DTI with sample was going to be my method as well. Another method is always nice to know.
          Bill
          Bill
          San Diego, CA
            For those of you with compound slides that are a rounded in design, I would think that perhaps cleaning the paint and filler off a spot (or even spot facing one place maybe 3/8" diameter) and then using a set screw to fine adjust the L-shaped piece for square to the lower slide half would do the job. In effect, you would be adding a jack screw and then using the L-shaped piece as a bit of a sine bar. Once adjusted to the proper height, drip a bit of cyanoacrylate on the screw threads and let it wick down in....or use a piece of monofilament line down in before threading the set screw in as has been recommended here by others. Its a cheap way of making a set screw into a locking set screw.
            Paul
            Paul Carpenter
            Mapleton, IL
              Fantastic job Frank!
              How is the 12L14 holding up on the drive center? Does it look like it will last in a home shop environment?
                You know, you have the makings of a lot of good articles on your website. You should sell some to H.S.M. magazine. It could pay for a lot of new tooling for you.
                  Actually, I had one published a while back, and the next issue of Machinist's Workshop will be running a short article on making a simple form tool from an old file.
                  I have written a lot for magazines over the years (mostly guitar related) and yes, it does help pay the bills.
                  Next issue of MAKE Magazinewill have one of mine, too.
                  I suppose the 12L14 will hold up OK for me, because none of my tools get all that much mileage - only so much "spare time" you know.
                  Offhand, I don't think it would be a good idea to have both the center and the drive pins spring loaded. I'd be afraid of not being able to get enough "bite" unless the springs were bottomed out. And, the force along the axis of the work would move the part being turned with the carriage going to the left.
                  Frank Ford
                  FRETS.COM
                  My Home Shop Pages
                  Frank Ford
                  HomeShopTech
                    I thought HSM just pays a pittance (~$50?) for an article?
                    That's a really neat site Frank! I'm surprised I never ran across it before...
