Early Jacobs chuck taper
  • Early Jacobs chuck taper
    I have acquired a Jacobs chuck that I can't easily measure the taper
    but have tried a #3 and #33 and both are too large. Don't have any
    adaptors smaller. The info on the chuch is as follows:
    375 PORTOMATIC chuck 0 - 3/8"
    The Jacobs Mfg. Co.
    Hartford Conn USA
    Pat applied for.
    I checked the Jacobs web page and ther is no such model number
    listed. ( probably too old a model)
    Does anyone know if it is a #2 or short#2 or is it from before tapers
    were standardized? :-)
    Thanks
    ...lew...
    How about a Jacobs taper #6 Bet thats it.
      Originally posted by Lew Hartswick
      .....Does anyone know if it is a #2 or short#2 or is it from before tapers
      Thanks
      ...lew...
      Lew,
      Machinery's Handbook lists, Usual capacities for each taper. #2 is for 0-1/2". #2a (short), 0-5/16". So, probably a # 2.
      .5590" Large end of plug, .8750" long, .48764" small end of plug.
      Lane, #33 is smaller than a # 6, and that did not fit.
      Les H.
      The Impossible Takes Just A Little Bit Longer!
        Try a 2J Jacobs.
          .5590 (large end) is #2 Jacobs. Jacobs also made a .625 straight mount. Make sure it is indeed tapered.
