Bolting down a lathe
  • Bolting down a lathe
    I finally got a REAL machinists level and will be checking my lathe right this time. If all is ok or if I need to level should I bolt it down or does it really matter.
    I never bolted it from the begining because I do not feel a 13x36 could ever be worked hard enough (within reason) to make bolting it down needed. The other way to think would be since it is light it should be bolted.
    Now it will be a bugger to bolt it so I wanted to have some discussion on bolting them down.
    I am serious about this so lets have a discussion.
    Life Is Grand
    bolting down is not needed unless you are running the hell out of it and it starts walking around when running balls to the wall.
    put it on a flat place with some studs to hold it still and run the hell out of it. lathes dont need bolted down tight at all.
      I live in EARTHQUAKE country! Bolting down is very important.
      Bob
        There's a few ways to look at this. Here's three- bolted solidly, not bolted at all, or set over pins that are just locators.
        First we'll assume your bench is solid. If you place rubber discs under the lathe's feet, then put some rubber hose pieces over some lag bolts, then bolted those through the feet and into the bench- not torquing them down over the lathe's mounting lugs- that's what I'm calling set over pins. It keeps the lathe in place, but doesn't add to the rigidity of the bed at all, plus some of the vibration is kept from transferring to the bench by the rubber discs. If the bench isn't flat, the lathe will be wanting to rock to some degree, unless it has only three mounting lugs. I'm assuming for now that it has four.
        Next is solidly bolted down to the bench. In this case, either the bench is warped to suit the lathe, or the lathe bed warps to suit the bench, or you shim carefully to keep the bench solidly on all four legs while preventing any twisting of the bed. (or actually applying some twist to the bed as required for alignment) If this is done right, the bench will help the lathe bed to stay aligned. This assumes of course that the bench isn't warping for any reasons, like humidity changes, floor level changes, etc.
        Not bolted at all- well, the lathe would be free to move around, and could get into a vibration mode that would be dangerous. Some off-center chucking and certain speeds are most definitely going to cause some problems.
        It's possible that it boils down to this- if the bench is solid and doesn't warp for any reason, then bolting the lathe solidly to it allows the bench to control the bed and can help with the alignment. If the bench is queasy you would not want the lathe to be solidly bolted to it since it would alter the alignment- but you lose the capability of aligning the bed because there's nothing to torque against to do that.
        Does that lathe have a three point mounting? If so then the bench can't be used to help align the bed, unless you bolt a bar under the tailstock end, and have both ends of that bar as mounting lugs. My own preference, because my lathe is short and a three point, is to solidly bolt the headstock end and leave the other end snug but not tight.
        It would seem to me that a longer bed would benefit a lot from a solid bench, as long as that benchtop stays flat. In that case, I'd say bolt it up solidly, but carefully shim and align the bed as you do so. It doesn't take much movement of a bench's feet to throw it out of whack. Some means of keeping them in place on the floor can make a lot of difference.
          Why?
          I have an open mind on this topic but I've yet to see definitive explanation of why "leveling" or "correcting twist" is either really necessary or practical in the general case.
          Well, that's as maybe.
          Yeah, I know, that is just about the biggest heresy of all to some.
          Perhaps some of this "Holy Writ" stuff as regards machines is "Bull**it" and I can't see why I can't question it.
          If it's all "cast in stone" - then show me.
          I'm not interested in the "everybody says/knows/does/etc." or "So and SO - an acknowledged Guru says so" stuff.
          In the immortal words of Prof. Julius Somner-Miller: "Why is it so?"
          Generally, the "box" or "ribbed" section of a lathe bed frame is a rigid as ................ and will not be moved much without significant torque and a base that is capable of resisting it.
          How are you going to limit the "correction" to any part or parts of the lathe bed? How are you going to stop it twisting at the head-stock or tail-stock.
          Does it really matter in the grand scheme of things?
          Why is the assumption always that the distortion is a "twist". What if it is a "hog" or "sag" (vertical and/or horizontal) and if so how are you going to correct THAT? What if it is all three? How would you know?
          I am reasonably sure that if my lathe was 5, 10 or 15 degrees - or more - out of level - in both the longitudinal or transverse planes that it would not make much if any difference to the operation or efficiency of the lathe.
          I have a "super-good" Machinist Level as well, and to be candid, it is a PITA to use and so back in its box it went and there it is staying.
          I get by very well with a good accurately machined square box-section Carpenter's level which has an accuracy of better than 1mm per meter - 1:1,000 which is 0.001 which is the ArcTan or ArcSin of 0.057 arc degrees = 3.438 arc minutes.
          Just to put that into perspective: your average "Chippie" has a tool with an accuracy order of magnitude better than the calibration of most rotary tables and vernier protractors which are calibrated/read to 5 arc minutes!!!.
          Similarly, how many worry themselves stiff getting a lathe head and tail-stock aligned only in the lateral plane? How many actually run the DTI over the TOP of the test piece and see if the head or tail stock centre lines are parallel to the lathe bed in the vertical plane?
          What about my lathe? Is it bolted to the bench (steel)? Yep? Why? to keep it on the bench. What's going to "give first? The bench (I hope!!).
          If all this is so critical, why isn't it mandatory on precision grinders and Tool-Room lathes etc? Most are on 3-point suspensions and usually on resilient mounts.
          The only thing I make sure I get level is the grinding wheel balancing stand for setting the balance weights on my surface grinder balancing weights/flanges. That's all. And I set it up each time I use it where-ever it's handy and I use my Carpenters level!! Any good? Too right. How good? When I've set the balance on the wheel and set it on the knife edges, the wheel either runs end-to-end freely without stop, or if stopped - stays stopped.
          If I were concerned about anything on my lathe bed it would be to put an accurate straight-edge over the top and sides of the bed. If there were "bending" in the horizontal or vertical plane/s I'd really have a problem and all the "corrective twisting" in the world applied at the lathe-to-bench/floor supports won't change it.
          And while I'm "on it" - what if your mill table or vertical slide-ways were bent or twisted? How would you know? And if you did, how would you correct it? Or could you? Would you?
          Anything else?
          Yep.
          I will get a very accurate "Machine Square" aka "Precision Frame Level" for checking my squares and machines for "square/ness".
          http://www.hareandforbes.com.au/sample_2/home.php (top left) as it had the same order of accuracy as the "Machine Precision Level" (0.02mm/1,000mm), will do the same job, is marginally cheaper and is ground "square" to a very high order of accuracy.
          All of these "high end" "levels" need to be checked and re-set (if necessary) each tim ethey are used. Know how to do it? No? Why? The theory is OK but this too can be a real PITA in the application of it as its as "fiddly" as bug**ry.
            None of the commercial shops I’ve been in have lathes bolted down.
            50-60.
              So far it looks like it is 50/50 the good thing is that we have a discussion and I am seeing reasons why I would or would not bolt it down. With that I can make a decision.
              That being said I should have said I have a Grizzly G4003 which weighs a little over 1000 lbs. It is bolted to the stand which is sheet metal cabinets with heavy tops and bottoms. There are two connected with a sheet metal strip. By themselves they are somewhat weak but together I feel they are barely adequate.
              The lathe does have 2 solid pedestal mounts like a square column. They have 4 bolts each.
              I did level it with a high quality carpenter level actually a Starret which Enco played up to be a machinist level but it is a carpenter level but a very high quality one.
              Always wanting a machinist level I finally got one accurate to .005 in 12" which is not the NASA version but should do fine in my case. If it is off it should be consistently off so .005 on the way should not be a problem.
              Good point so far on all sides. I am not ready yet to decide. Anymore real life stories about this that can be shared?
              Life Is Grand
                From a practical point of view, if the mounting holes for the
                lathe bench are not oversized, unless you use a diamond
                core drill to make the hole, putting 4 holes at precise spots
                in concrete is a bugger. Aggregate in the concrete or steel
                if present can shift holes all over the place.
                On another point, once I had a machinist level, I was amazed
                at how easy it was to move the bubble when the level was
                across the bed of the lathe, lathe bolted to the stand and
                sitting on 1/2" bolts and pads just by pushing down on the
                bed with my hand. Gave a new insight into how rigid 1200
                lbs of CI/steel was, or perhaps I was just flexing the concrete
                pad.
                  At the risk of seeming to be overly diplomatic, I think it depends upon the type of work you are doing and how much accuracy do you really need. I have a 14 inch Clausing and a 16 inch Monarch lathe and neither are bolted down. I also have a concrete floor that is reasonably level, and generally speaking, I don't work either of these lathes very hard, but then there is always that "special" job that falls outside of my "usual" type of work where I'm either hogging heavy cuts, or where I need extreme (for me) accuracy. I can honestly say that for each of my lathes, I have leveled them each once, and then I check them periodically. Neither has ever moved that I can detect. I would work with it, and if repeatability or accuracy becomes an issue, then I would take the necessary time to level it out and then bolt it down. As with anything else, if you have a problem, you either live with it, or keep going until the problem is resolved to your satisfaction. I do know from experience that a twisted bed will not give repeatable accuracy over the entire length of the bed. This is not a myth, it is a fact. But having said that, most lathes are pretty heavy, and made from subsatantil castings, and due to that, a lathe bed that is actually twisted is somewhat rare assuming that you set it up properly to begin with.
                  There is no shortage of experts, the trick is knowing which one to listen to!
                    I have a question Ed, what does either of your US made lathes weigh? I am curious if Chicom made is as heavy as US. In my eyes this plays a very important role in whether to bolt or not to bolt and yes how hard you will work it and how accurate you want to be is also a factor.
                    Life Is Grand
                      I have a friend who is a highly qualified machinist at the Naval Shipyard, he bought a Chinese 12 X 36 gearhead lathe and put it on a wooden bench. He made no attempt to level it and gets great results from it.
                      I bought one just like his, I had a steel stand made from 1 1/2" angle and 1/2" plate, I have leveling feet on it and leveled it with a carpenters 24" level before mounting the lathe. When I put the lathe on it, I bolted the headstock down and let the tailstock float, it has no obvious gaps between the tailstock and the support. Similiar to what Darlle said,
                      "My own preference, because my lathe is short and a three point, is to solidly bolt the headstock end and leave the other end snug but not tight"
                        ok, i'll take a poke at it....
                        levelling is just a convenient way to measure twist, except for say coolant flow, being level does not matter. twist does, it changes the the tailstocks position relative to the spindle axis as it moves over the bed and also the carriage. try to set up a lathe to not cut a taper for the tailstock positioned at various points along the bed when there is a lot of twist in the bed
                        cast in concrete, carved in stone ...ok, agreed, that was nitpicky of me
                        Baloney, set up an 10th's indicator on a piece of work and start leaning on various parts of the machine, you may be surprised at what can move the needle...and that's on a 13x36 standard modern. Any force causes deformation, there is no such thing as rigid. granted, the amount of deformation might be small, but often so is the amount we're trying to be accurate to. the rigidity of the bed and stand will not prevent twist. Certainly bolting down on the floor will twist it, unless by divine intervention all the contact points in the floor lie perfectly on the same plane.
                        twist misaligns the headstock and tailstock axis, if it was just sagging, the axis are still aligned and the tool bit distance to the axis is not meaningfully changed. The point is valid though, that's why high end lathes like the monarch and hardinge are so much more massive - to minimize the deformation under load.
                        yup, so long as there wasn't twist, that both ends were out the same.
                        the vertical plane doesn't much matter, so long as its close. dropping the tool bit a thou just doesn't much change the distance from tip to axis much, did the math once to prove it to myself. being out horizontally however will of course cut a taper
                        that grinding machines rest on three points support the argument that its critical to avoid twist - they circumvent the problem by resting on three points. Again, being level matters not....a level is just a way to measure twist and twist does matter.
                        you don't need to do this so long as you orient the level the same way when you go from headstock to tailstock. as you are using the level to indicate twist it will do so perfectly without being set, so long as you don't turn 180 degrees.
                          My Clausing 6300 has leveling screws between the bed and the stand. I level the stand with (6) 5/8 jacking screws on metal pads touching the floor. 4 at the headstock and 2 at the tailstock. I torque them to the same value and lock them down with nuts. I then level the bed to the stand.
                            I'm not Ed, and my lathe's British, but my 13" Clausing Colchester Master 2500 weighs about 2200 pounds. Shown here parting off 4.5" PVC rods.
                              Klem, both of my lathes are American Made from a time when that term actually meant something. I don't know the actual weight of either the Clausing or the Monarch but both are heavy. I would estimate the Clausing at about a ton, and the Monarch at about 4500-5000 lbs. The Clausing can be moved about with a die mover cart if done carefully, and slowly. with the Monarch, forget about it. The Monarch is heavy enough that when our local welding shop owner set it in my shop, he had an admittedly small crane, but he got to experience what it was like to operate it when on two of its pneumatic tires, with the other two suspended in mid air. Suffice it to say that it is sufficiently massive and heavy, and not easily moved. I can honestly state that I know of no engine lathe made today that can compare to the Monarch in terms of mass, weight, and rigidity, although I've never conducted a formal study to back that statement up.
                              When my son first saw it, he pronounced it to be "beheMothic", and since it is a Monarch, I now refer to it as "Big Mo". It is truely a magnificent machine, made in 1943 to support the War effort.
