VDF for two motors on a Wells Index 645
  • VDF for two motors on a Wells Index 645
    i got to lookin,
    and ive got my main motor,,,
    220V 0r 220-440, 3phase,
    ive got a lower motor on the power-feed transmission, all axis,
    thats 3phase only,,
    looking for someone to help me pick out a VDF unit for both,
    as im electricaly challenged,
    itd be nice to have someone help me, who knows about this stuff and give me the web-page and part number,
    maybe dealers electric??
    main motor, tag says,
    code-L HP-1
    RPM-1800
    cycle-60
    Volts-220-440
    AMPS-3.6-1.8
    Duty-cont 0C rise-55
    may be used on 208 volts system--stated at bottom of tag,
    small power-feed motor
    model I4053 A SER B-63
    208-220/440 Volts 3 PH
    55 C rise cont frame 56
    1725/1425 RPM 60/50 cyc
    1.2/.6-1.3/.65 amps 1/4 H.P.
    code L type TE
    delco products
    ive taken pics of the motor tags, and i can email the pics to you, so youll have all the info,
    i need to get the photbucket set up yet,
    thank you,
    EI
    Why not call Well Index and ask them for advice. I think they are the only American Mill maker left. They are located in Muskegon, MI. Gary P. Hansen
    In memory of Marine Engineer Paul Miller who gave his life for his country 7-19-2010 Helmand Province, Afghanistan. Freedom is not free, it is paid for with blood.
      Not to get off topic, Hardinge bought the Bridgeport name. Hardinge is manufacturing the Bridgeport Series I mill in their New York facility. If the same is true for their CNC lines, I do not know.
        i put a vfd on my well index head , got a Teco Fm 100 from Dealers electric.
        I pulled off the start, stop, reverse lever as supplied ont he machine- it was crushed any way and made a plate and bolted the VFD on its place- so its on the left of the machine head.
        you need to be able to reverse the rotation as the spindle changes rotation when you get out of back gear
        havent had the time ,but I want to go and use the aux strip on the VFD to run a couple of start stop buttons ,and a revese switch as well
        - i did this on a adrill press it works quite nicely.
        on the mill i have to stop and think about what i am doing to operate the small buttons on the keypad, and acouple of times have hit reverse or forward by mistake and the mill stops and restarts in forward when i wanted it stopped.
        on the drill i put one stop switch that i can hit with my foot and one i can head butt if need be - for when your hands are full and the machine needs off - NOW
        i would suggest something similar for a mill -
        I am assuming you have the old style power feed - that is located on the left side of the knee , driving the feed screw through a shaft and not a newer stylr servo power feed that hangs where the handwheel goes on the right side of the table.
        shouldnt be a problem with that
          Originally posted by thistle
          you need to be able to reverse the rotation as the spindle changes rotation when you get out of back gear,
          Please explain this to me, im not following it,,,(the back-gear)
          is there instructions for doing this??
          thanks
          EI
            In low speed the spindle is geared , in high speed it is direct drive, the spindle goes one way in high speed (direct drive) the other in low speed (geared drive).
            hence you need reverse
            there are diagrams to show the differant set ups, which can be confusing if you are unfamiliar with electrical stuff, but if you are diligent and read up, or get some one who knows - no prob.
              I don't know how your motors are wired, but, there could be a problem with driving both motors from one drive unless their both always on and off together at the same time. VFDs don't like their output loads being switched on/off while power is applied.
              If doable? Replacing the lower 1/4h motor with a single phase motor might be cheaper than it's own VFD.
              Tom M.
                www.vfds.com has some 1/4 hp VFDs, but Tom's idea of replacing the motor may be more to the point.
                Instructions for wiring will come with the VFD(s). If they are anything like the instructions that came with mine they will be:
                1. Complete
                2. Opaque
                It will likely take careful reading to extract the information for wiring up remote control buttons, but based on my experience all the information is in the instructions, if you cogitate sufficiently.
                I've seen VFD instruction manuals online someplace; try poking around www.dealerselectric.com or www.vfds.com or other VFD site and see if you can find some. It will give you an idea of what you may be getting into.
                  Buy a separate VFD for this motor. They're very affordable these days. Besides, when you replace three phase motors with single phase you're lowering the machine's resale value.
                    I dont understand the "back-gear part"
                    ive got a 2step pully on the motor,
                    that goes to another pully system in the back,
                    then goes to the quil head pullys,
                    so where or whats a back gear???
                    ive got a switch, forward, off, reverse,,,
                    thats it,,, 90-2700 rpm
                    see it here--pully system
                    http://s228.photobucket.com/albums/ee209/elginiron/
                    EI,
                      Vdf's
                      I just bought two, of them,
                      L200-002NFU,,,for the small motor,
                      and
                      SJ200-007NFU,,,for the large motor,
                      this is what the elecrical dealer told me would work with my two motors,
                      should be here in 2 days,
                      EI
