what a paint job look at the motor
  • what a paint job look at the motor
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...tab%3DWatching
    In THe ad the guys states this
    I've never used this, don't know how to," I just did it up" but it works OK
    He'd better have left it alone look at the paint job on the motorAlistair
    Alistair all I saw were a few runs, Don't you know thats so it will run faster.....
      At least he took the trouble to mask off the sliding surfaces etc.I've seen a lot worse.
      Hans
        ok guys I admit it it is better than mine that's why I am jealousAlistair
          Wow, check out that "Raised white letter effect".
            Surprise, surprise!!
            Well, well, well.
            All that comment on the motor that is dismounted - but there is still one on the lathe (even though there is no power to it).
            And now the piece' de resistance' (tah, dah!!!):
            The key is still in the lathe chuck and not a comment on it!!
            http://i21.ebayimg.com/05/i/000/c0/07/d9e0_2.JPG
            Oh me, oh my.
            Things have progressed!!
              Alistair,the old country folks around here have a saying to desribe ugly-
              "That looks like a cows ass sewed up with a grapevine and painted with a pine top" They aren't known for holding back thier honest opinion
                That's a damn site nicer paint job than the typical Ebay Machinery Dealer: polish all exposed metal with ScotchBrite and cover everything with a thick coat of dark paint so it's hard to see wear.
                There's been a bunch of really sad "rattle can" paint jobs posted on PM, where the seller just covered everything in paint, including the leadscrew, the change gears, the ways, the compound, ... Those kind of guys are usually in such a hurry that they don't bother to cover the floor, and there's a huge paint shadow on the floor where they went crazy with the spray paint.
                I've also seen sellers spraypaint gun blued (black oxide) handles and handwheels with black paint, to hide wear.
                I think there should be a special place in Hell for the Rustoleum abusers. They should share a cell with the guys who leave machine tools outside for several years, then list them on Ebay as having "surface rust."
                  But they DO have "surface rust".
                  Every surface IS rusted, and very well done, at that, so why are you complaining?
                  I'd call it truthful advertising........
                    Right on
                    You got it JT.
                    Loved the "sly dig".
                    The rust where it might be a worry is there to see - appears to be minor surface rust anyway - and if that's as bad as it is then that lathe might be OK.
                    As you say - truth (even if unintended - but I don't know that) in advertising.
                    The rest of the paint job looks OK and there are no visible serious faults.
                    But that's Ebay - "yer pays yer munny 'n' ya takes yer chances".
                    Having said that, there shouldn't be anything wrong that a half competent HSM couldn't fix or work around to use the lathe until he gets around to fixing it.
                    The motor should easily cleaned - as long as it works, that's OK.
                      I guess the clarification I would make is how far down does the surface rust go.
                      We've all seen machines that were left outside, and unless you live in Arizona, it's not a pretty sight.
                        This is ugly.
                        Same lathe. 3 months later.
                        But I wouldn't call it done yet. I just got done rebushing the gear train and now it's humming instead of howling. But I still got issues in there in that I need to make some new shafts. Unfortunately the worst one, (tapered .010), has a woodruff cut and I can't do that ... yet.
                        It's all good tho. As soon as I get my XLO mill refurbished I'll get back in there with some new shafting. Given time and a continuing education from the fine people on this board these machines are gonna be a couple of sweet pieces someday.
                        SP
                          Beautiful job SP!!
                            what I found funny was that he said I done it up.That usually means your proud of the work, you did and you made an improvementAlistair
