End Mill Quality
  • End Mill Quality
    Hi,
    I just won a bunch of end mills in an auction { not Ebay }. They are mostly Niagara (USA) and Sossner (Japan?). What's the quality of these two brands ? I assume they are pretty decent. I have had no issues with them, just curious.
    Thanks,
    Kevin
    High to very high quality.
      Don't know about Sossner, but Niagra(sp?) is top line from what I've seen. At least I've had very good service from the Niagras I've used.
      Russ
      Master Floor Sweeper
        They're both top names for quality. Assuming the end mills you got aren't worn, they ought to serve you well.
          Hi,
          Niagara mills make a most satisfying "snapping" sound when they break. Hey, sometimes one can forget to edit feeds and speeds when re-using a program
          Sossner tend to cost more than Niagara.
          dalee
            Both are excellent quality cutters. One of the things beginners often fail to recognize is that there is a reason a good mill cutter costs a bunch of $$. They usually buy that box of "20 END MILLS TICN!!! $40!!!!" from eBay or ENCO, and wonder why their cuts are ragged and poor quality. A good end mill costs more than $2. The accuracy of the grind, geometry, and sharpness, all combine to make a good cutter fairly expensive.
            There's one exception IMO - a cheapo ruffer generally works well since you are leaving some material behind for cleanup, anyhow.
              How did you know I bought the cheapo box first ? I bought A lot of cheap crap to get started and have been looking for good stuff at local auctions.
              I bought a box of 200 end mills for $50 at a machine shop auction. They are all razor sharp. Looks like I got a great deal !
              Thanks for the info.
              ~Kevin
