Norton grinder Running Finally
  • Norton grinder Running Finally
    Had loads of problems with a surface grinder i had picked up. The motor was cooked. New motor fitted with some difficulties but now working. I am using a three phase motor with a single phase to three phase invertor with speed control. Now my questions this What rpm should the grinding wheel be spinning at. ??? I have a mechanical tachometer and when the motor speed control reads 2800 the wheel is spinning 2050 rpm only. I think this is too slow?? Whats your Opinions on this matter Guys??? Also it is leaving a odd surface finish on the part looks almost rippled but feels smooth. Any ideas?? I thought it was perhaps the sopindle running too slowly?? Thanx Mike
    There are many possibilities Mike.
    Take a look at this thread from the PM board:
    http://www.practicalmachinist.com/ub...c/1/27483.html
      Norton Site
      I couldnt find recommended rpm of wheels in the norton Site. I am surface grinding with a toolroom grade 7 inch diameter wheel. ???
        Grinders that run that size wheel usually run at 3450 or 3600 rpm's. Your finish probems could be so many different things that it would be hard to even come close to guessing with the information given. I would probably start by looking for vibrations though since you just installed a new motor, any small amount of vibration is going to transfer into your part, also is your wheel balanced? and did you dress the wheel after installing it?
          Rpm Problem?
          I think my electric motor isnt spinning fast enough. I am getting only 2050 rpm at the grinding wheel. I just ground in my new magnetic chuck and am building a grinfding cam for a centerless grinder a friend has. I encountered odd finish marks on the surface. I am going to try to repriogram the vfd to allow more rpm. I would like 2840 rpm at the grinding wheel.
