Die filer video
  • Die filer video
    First I've seen: http://www.youtube.com/watch?v=TpTZyx5Whig
    Short but informative. It would be interesting to see more vids of operations on machines that were once common place.
    Bring your Video Camera and come to my shop, watch me work every day.
      Thanks for the damn post. You just drove up the price of die filers on ebay for me. I been looking for one
        Die Filer speed
        Thanks for posting the video. My die filer runs much faster than that - about 600 rpm, I would say - and vibrates so much it is useless. Is it just running too fast? Does anyone know what the correct range of speeds is?
        My unit is a Keller 1A with a 1/4 hp 1725 rpm motor (non-original). The driven pulley is original and just fits inside the belt guard. The driving pulley can't be made much smaller. The ratio is about 3:1. The unit in the video seems to be running about 150 rpm. To get that speed, I would need a motor running at about 750 rpm - not a common item. Suggestions?
        My unit is also missing its overarm. Anyone know where I could get sufficient information to build one?
        Thanks.
          I like that he put the video up - but I might be a little biased in that I am probably going to put my completely redone but now spare die filer up on ebay .
          Charles
            Thanks.
            600 stokes per minute does sound a bit fast. One cheap and easy solution to slow it down would be to put a dc treadmill type motor on it for variable speed. You could use your pulley dimensions and slow the motor down until you get a spm that you are satisfied with. Hope this helps.
            Jonathan P.
              Thanks.
              Who about this two speed motor on ebay for cheap?
              http://cgi.ebay.com/ws/eBayISAPI.dll...m=130175142017
              Not quite 800 RPM but definitely slower. Charles
                Thanks for reminding me that I have a homebuilt that I never finished.
                Even worse is the memory of the floor model die filer I missed on ebay because my ISP took a dump 20 minutes before it ended
                On the bright side I did find this niffty corprate PR video
                http://www.youtube.com/watch?v=3wy8i...eature=related
                  Dang Wierd... That Pakistani narrating the video is the same guy who answers the phone at my credit card company customer service line.. LOL JRouche
                    this must be one of those tools that you can only appreciate once you've had one?? as I've yet to file a die, i just don't get it. I use files all the time, to remove machining marks, clean up a weld, get something flat, on rougher fabrications to clean up an edge after sawing or even torching - non of which a die filer would be much help with. I can see it for squaring up an internal corner, but for the infrequency of that doing it by hand seems ok
                    so what am i missing? and where the heck do you buy the die files - no taper, straight tang and teeth cut toward the tang...can't remember ever seeing them in a catalogue.
                      Keller still makes Die filers and sells the overarms seperatly. Mine came without them as well. They ain't cheap!
                        removed since Mcgyver edited his post.
                          Charles
                          You putting it up before or after Christmas? You'd likely do better after the holidays. (I know I could afford it better then!)
