Small project pics
  • Small project pics
    So, a buddy needed a part that he couldn't find anywhere. Since it's some kind of beer keg adapter I felt morally obligated to help out.
    So...
    That piece on the right was actually two brass pieces that I machined to fit one another and then brazed together. He ASSURED me they were stainless Anyway, I should have taken a "before" pic, but oh well. He needed to get from that threaded nut on the bottom to the quick-disconnect fitting on top...
    But...
    That spring loaded seal in the middle (poppet, I think) needs to bear up against something for the spring to create it's seal in that hole on top of the quick-disconnect... with the two pieces joined there was nothing for it to sit against...
    So, I machined this little plug to match the internal threads of the quick-disconnect (with a hole through it so the beer can flow).
    I added those 4 recesses on the mill so it would accept a big phillips-head screwdriver:
    Fits nicely:
      Hi Magee
      Now thats nice !
      Mogens Kilde
      http://m_kilde.skysite.dk/
        No greater glory can a man achieveth, than that which he earns when he donateh his time at lathe and mill so that the BEER may flow!
        Well done Magee! And have a happy and safe Thanksgiving.
        NRA Life Member
          Another success story. Nice job! This may qualify you as the "Food Grade" machining expert .
          Frank
