Small O-rings
  • Small O-rings
    Would anyone know of a supplier for small o-rings. Exemple: O.d. 5/16 W. 1/32. I live near Montreal so they must accept to ship small quantities if it is in the U.S. or another province. I actualy need about 60 of them.
    I'd recommend American Seal, Inc.:
    http://www.americanseal.com/
      Thank you for submitting American Seal, but after checking their web site we see that as other suppliers, the smalest cross section of their standard seals (w) is 1/16 of an inch and I am looking for 1/32
        See if you can locate a rebuild shop that repairs diesel injector pumps in your area.One in this area had just the size I needed. They get kits that fit all kinds of applications and only need some of the parts.They gave me a large plastic bag,about 5lbs.of new parts that usually get thrown away.O rings of all sizes and discriptions,rubber seals,pins,gaskets,screws,etc.
          Check out your local weld supplier. I have replaced some of the tip-to-handle o-rings on my Victor Junior and they are smaller than anything I could find at my usual sources.
            Try Small Parts Inc
              Apple Rubber Products Inc. 1-800-828-7745 www.applerubber.com
              Their 1989 catalog lists a .311X.031 as one of their standard sizes. I'd ask for their catalog.
              O
                Look them up in www.thomasregister.com it "only" has about 65,000 manufacturers listed. If you cannot find it there, good luck finding them...
                  Thanks to you all for your kwick response. I appreciate your informations and suggestions and starting from there I will probably be able to find those O-rings.
                  [This message has been edited by mauricep (edited 12-01-2001).]
                    Reid Tool Supply ships in small quantities and is a nice company to deal with (usual disclaimers). They sell O-rings, but I'm not sure if they have the size you need or not.
                    See http://www.reidtool.com/
                      Try allorings.com
                      They may have something with your diameter. They have been great for my needs in the past. Great service and small quantities available.
