I have been practicing my engraving skills the last few days and have managed to make the same mistakes only once each time, so far. The machine works great which is more than can be said for the operator.
This machine has a bit more grunt than the average engraver such as the ancient first generation New Hermes CNC engraver I used to repair for a local Jeweler. One way this can be used to advantage is to do "scratch engraving" in which the tool is simply dragged along the metal. Done right this displaces the metal neatly instead of cutting it and doesn't use the spindle motor at all, it is turned off. Your average dedicated engraver machine such as the old New Hermes isn't up to that as it requires several pounds of downforce on the tool.
It also requires very even pressure on the tool to produce a good result. One way to achieve this is to use a spring loaded tool. This also eliminates completely problems caused by slight warps in the metal being engraved and greatly simplifies clamping.
Yesterday I made a spring loaded engraving tool and did some testing with it. It is really nice and a lot less fussy to set up. It does a great job on aluminum, brass and silver. The tip is high quality carbide salvaged from a broken 1/16" solid carbide end mill that I had lying around.
The tool fits in a 5/8ths R-8 collet. It has an integral 1/8th inch collet chuck for the tips. Travel is about 1/4" with midrange exerting about three to five pounds of force. The tip of the tool has about a .010" radius.
The results speak for themselves.
That's my daughter. She is the best photographer I know. She just bought her third Canon XTI as a backup-backup camera. You can see her work at crazywolf.com
