Just ran across an article in the Fall 2007 Digital Machinist - "Drag Engraving Tool For CNC Mills" Though different in configuration, the tool is identical in principle to Evan's.
They are an ER11 collet chuck with a 16mm ground OD and a JT1 taper in the end.
Although they are hardened it's possible to cut a slot in the side for a peg to fit and allow it to slide in a holder. My holder is a blank R8.
Can you post some pictures of what you have done? I was also curious as to why you slotted the collet chuck and not just drilled a hole for a pin? I'd have thought this would have been easier given the shank is hardened.
Dave.
Can't post any photo's as the demo machine is in the showroom a fair distance away and this tool is with it.
I can sketch it out later and post the sketch.
It's quite simple, not far off what Evan has but a bit inversed, my spring is inside.
The reason I slotted the outside, just a keyway really, is that a pin in the holder stops it turning and still allows it to float.
Although these are hardened a carbide 4mm cutter will soon slam a keyway in these.
You could pin the chuck and slot the body but it's then harder to strip down , my pin is an allen grub screw with the end turned down parallel.
The spring is adjustable by a screw fitted right down inside the 7/16" UNF drawbar thread as mine is on a R8 fitting.
As Evan says they need to be a good fit, mine runs in an oilite bush.
They aren't new, they have been around for years. Dick Stevens did one in MEW a few issues ago but he made his collet chuck based on an Eclipse pin chuck.
I don't have the time for this and if I can buy off the shelf reasonable then it save me money hence the use of the ER11 collet chuck as they are readily available and so are the collets.
Hello all, new here. Evan I realy like your tool holder. Would you be interested in making me one with a 1/4 or 1/2 inch collet size.If not I would understand. Where would I source the parts for such a tool holder? Thanks in advance.
I almost didn't notice this thread had risen to the top again.
This isn't a good time for shop work. I don't get near enough time for my own projects during summer as I have many other things to do. This week I will be mainly fabricating some gates for the fencing we put in earlier. When I do have some time in the machine shop I am working on an electric power unit and transmission for my bicycle.
What I am trying to say is that I can't spare the time to make an engraving tool right now. If you are still interested come next winter let me know and I will consider it.
That's not very nice Lin. Even if I didn't know anything about machining but was somehow introduced to what a CNC can do I would buy just because they are so cool. It's a tool and one can never have too many tools... Humans are tool users. Only a few are tool makers.
Far too stiff a spring. It doesn't take much spring pressure to displace the metal when it is multiplied down to a tip that is only a few thousandths in radius. If the pressure of the spring is one pound and the tip has a contact area of .003 x .003 approximately then the pressure at the point is around 100,000 psi which is why it is able to engrave mild steel just fine as that exceeds the plastic yield.
