I have what I think is a fairly simple question. I have a Dewalt brand 14" Mutlticutter cut off saw. If you are not familiar with what it is, it's brief description is as follows. It uses a ~1500RPM motor and 14" carbide toothed blade designed for metal cutting. It will cut virtually any material, wood, plastic, and metal. I use it almost exclusively for metal cutting, it is faster than abrasive, or a band saw and the cut it makes is very clean and low heat.
Anyhow, the table on the saw is junk. It is stamped sheet steel and in the 6 years or so I have owned the saw, I have already replaced it once. The sheet metal base warps easily with heavy stock weight and after that it is difficult to get square cuts out of it. As if that isn't enough, the clamp and adjustable fence are about garbage. I have no complaints about the saw, other than the table.
This leads me to my question, I intend to make a new table for it out of solid plate. Originally I was going to use some 3/4" thick sheet steel, but I recently discovered that on Ebay I can get some cast aluminum 3/4" thick plates for less than I can buy the steel locally. My question is, do you think the base will hold up if made from aluminum? It will be much easier to work with when compared to a 100Lb chunk of steel. A lot of wood saws have an aluminum table, but I have yet to see a metal chop saw with a aluminum table.
My intent is a heavy solid table. A heavy, solid fence. Eliminate the tool less fence design and make one that can be bolted at common angles I cut. I haven't worked out how I will provide locking at other angles, but I will come up with something. Anyhow, will aluminum work, or should I stick with my original plan of a steel table?
Thanks,
Jason
Thanks,
Jason
