Hi All,
I think i'm having a senior moment - if I get a set of dies for a coventry die head can I use it to cut other threads with the same pitch than the size it was designed for.
Its just that I think if the tpi is correct then you should be able to cut any size at the same tpi but then I think weel it says only one size on the die!!
Any thoughts
Peter
Any thoughts
Peter
