Very fine threads
  • Very fine threads
    Hello everybody,
    I need to cut an SAE equivalent of M32x1 - give and take few since I will be making both sides myself. Could anybody please point me to where to find specs of such SAE thread and where to get the tooling?
    What is the biggest size for tap and die? I do not feel like learning lathe threading on something that small.
    Thank you
    If your going to use a tap and die you don't need to know the specs of the thread.
    You can buy the tap and die from MSC, Enco or any supply house.
    For the size of the shaft and the hole to tap and drill you will find them on a drill chart or in the Machinery Handbook.
    If your going to do machine work you need a Machinery Handbook. It's not an option, you need the information there in.
      Originally posted by Prokop
      Hello everybody,
      Thank you
      You are honestly better off biting the bullet and learning to do single point threading. You'll need it. 32mm isn't that small so there's lots of room to work on the inside thread and the 1mm pitch isn't very deep.
      OTOH, if you're set on buying the nearest equivalent tap and die you need to ask for a UNS 1-1/4 x 24. The tap manufacturers will make you one if you pay them, and you can call customer service for MSC or McMaster Carr to set it up. The next best choice might be UNEF 1-1/4 x 18 which is closer to a 1.4mm pitch FWIW.
      Good luck.
        I'd call that a LARGE thread.
        Yes, 1.25 -24 is the closest "standard" sort of thread.
        1601 2137 5683 1002 1437
        If you look closely at a digital signal, you find out it is really analog......
          If you've got the machine that will do the thread, just jump in. That should be a pretty easy threading job, and it's really no sweat at all to single point. I'm about as green/armature as it gets, and even I don't bat an eye and single point threads. It seems a lot more intimidating than it is.
          As for the tooling, can't help you there...
          Russ
          Master Floor Sweeper
            IMO, it's easier to cut fine (within reason) threads than a very coarse thread, and 24tpi or 1mm pitch is pretty reasonable. Don't be afraid to try! It's the way to learn, and nobody needs to know how many "learning experiences" end up in the scrap bucket....
            And yes, get yourself a copy of Machinery's Handbook. An older, used edition is fine, if you can find one. Maybe better than the latest, actually, since a home shop is typically somewhat behind the technology curve. Not that much of the information changes from edition to edition, anyway.
              1-1/4-24 would be close. I think it is listed in the Machinery's Handbook. Here it is
              External
              Class 2A
              Allowance .0013"
              Major Diameter 1.2487 max, 1.2415 min
              Pitch Diameter 1.2216 max, 1.2173 min
              Minor Diameter 1.1976
              Internal
              Class 2B
              Minor Diameter 1.205 min, 1.215 max
              Pitch Diameter 1.229 min, 1.2285 max
              Major Diameter 1.2500
              Page 1286 of Volume XIX
                That would be about a 1.25-24
                For 1.25-20
                Enco: www.use-enco.com
                Tap # 319-6437
                Die # 319-6506
                OR
                KBC: www.kbctools.com
                For 1.25-24
                Tap: # 1-372-432
                For 1.25-27
                Tap: # 1-372-434
                Sorry, I am out of time for now. Search KBC for a die. And remember you will need a tap drill.
                Make it fit.
                  ...You'll also need a honkin' big tap wrench and diestock. And something substantital to hold the work while you attempt to wind in a tap or turn a die that big. Really, I think it would be easier to do it on a lathe....
                    I would just jump straight in and single point it, maybe make a few practise runs first, and make the external thread first so you can use it as a guage for the internel...
                    Just got done doing a similar thread in Stainless on this part
                    http://i59.photobucket.com/albums/g2...ckFitting1.jpg
                    http://i59.photobucket.com/albums/g2...ckfitting2.jpg
                    The large diameter is 4" and yea i know the thread pic sucks but its not bad for a camera phone.
                    A 1" BSP thread comes out at around 33mm major diameter, and it was single pointed (did external too but havnt got a pick of the piece of tube it was raining and didnt want to bring a 6 foot tube indoors tonight )
                    As everyone else has said a 1mm pitch thread isnt much in terms of depth so it should be easy enough to single point, and its diameter gives you alot of clearance for when you do the internal thread. Threadings not all that hard once you jump in and give it a go and with a pitch like that you could even get away with plunging the bit as opposed to feeding in with the compound.
                    Good luck!
                      Probably need a pipe threading machine. That should do the job.
                      I was a bit tongue in cheek about the tap drill. I suspect finding a proper sized drill will be more difficult than getting the die and tap.
                      Personally, I would cut these threads in the lathe. Much easier and less expensive. It looks like the die and tap will cost well over $100.
                      Make it fit.
                        Prokop:
                        Did you make a typo? Your thread is anything but small.
                        Victor Machinery (victornet.com) has the tap for about $50 and the die for about $40. They have the largest assortment of special thread taps and dies I've ever seen, and at a reasonable price. (Just as an example, they list 1 1/4 threads of 7, 8, 10, 12, 14, 16, 18, 20, 24, 26, 27, 28, 32.)
                        Keep in mind that you'll need a whopping big wrench to turn those.
                          Thank you everybody,
                          most inspiring. Yesterday I started playing with my Logan and realised that it is much easier to cut thread than I always feared. I used just a pointed knife, but with bit of head scratching I was able to cut an outer thread 26 per inch. I think I will stay with SAE, since I have the gears for it. (Personaly. being from Europe, I can work with SAE but I prefer metric to that mess).
                          It always surprises me, how projects or skills I feared end up being quite simple, the worst part is to force myself to try.
                          I am sure for most of you guys here lathe thread cutting is not a big deal, but for me it is the greatest accomplishment this year
                          P.S. J Tiers, you are right - it is not very fine thread I need, large is the better word.
                            Same here.
                            So... 26 TPI isn't a fine thread? Out of curiosity, what would HSMers consider large, medium, and fine?
                              Originally posted by tony ennis
                              Same here.
                              When I cut threads they usually come out fine, but there are a few exceptions.
                              By specification, fine threads or coarse relate to the screw or bolt size so 24 TPI is a fine thread on 5/16, but a coarse thread on #10. Well of course, you say.
                              By feel, I think of a thread perhaps 32 TPI or smaller as fine, but I expect it depends on your field and experience. For miniature or watch makers it might start somewhere closer to 60.
