Machining hemispheres on a milling machine
  • Machining hemispheres on a milling machine
    There have been several threads here asking how to mill concave or convex hemispheres. I just noticed this YouTube video on PM which shows the textbook (Moltrecht, Cincinnati, Brown & Sharpe, ...) setup -- it's fun to watch. Quite the Rube Goldberg contraption to drive the rotab
    http://www.youtube.com/watch?v=3psLvh5ssPQ&
    Another way
    http://www.ipstool.com/Catalog/0185.pdf
    But you need to use the lathe. The ting I wonder about is just how does he control the size of his radii?
      And here's the final product: a beautiful bronze bearing for a 1916 locomotive:
      http://www.youtube.com/watch?v=fuZQsLR7ty8
      http://www.youtube.com/watch?v=8Pfc6q8t45c
        Originally posted by Spin Doctor
        Yeah, I have a Holdridge clone, but it's not nearly as cool as doing it in the mill
          Pretty 'simple' way of doing it, I can see some experimenting going on in the shop pretty soon.
          I'd read the method being described before, but apparently whoever described it had the process mixed up
          Wonder if there are practical limits to the smaller sizes you can do this way.
          Ken.
            Can someone please explain how a bearing can have another shaft at 90 degrees I just cannot see how anything can rotate!
            Peter
              As I see it, it rotates with the shaft and rides in something else (the two flat on the outside) the sherical section is to allow the shaft to rock a bit.
              Looks to be something of a U-joint actually.
              ken
              edit: would like to see the making of the shaft.
                How much do these holdridge ones cost and are they still manufactured??Alistair
                  They are high And yes still made by Holdridge
                    Alistair
                    Holdridge are quite expensive but are easy enough to homebrew.
                    Jon Bohlander
                    My PM Blog
                      That aint Rube Goldburg. Thats getting it done. Been their done that
                        As far as setting the radius, you measure from the front of the inner frame (Holdridge has flats on their cast frames) to the front of the tools and subtract the distance from the front to the center of the pin it rotates on. It's nice to have gages cut out of plate for the common radii.
                        Jon Bohlander
                        My PM Blog
                          Yes, the Holdridge Radius attachments are still made.
                          This site is on the internet has them for sale.
                          http://getmachiningtools.com/pro1115077.html
                          Here is another, or rather two other rare radius attachments.
                          The center, and left side components are a reduction geared feed head,
                          and adjustable internal, and external cutting bars.
                          The mechanism is outside the part, so the pivot point, or shaft
                          of the attachment does not get in the way of the machining operation.
                          The unit on the right is like a rotary table mounted in the slotted
                          bar.
                          Both will cut to center of the sphere. Most other attachments will not.
                          This is the offset setup machining a spherical socket (cannonball mold) in the lathe.
                          Kap
                            Here you are Ugly.
                            On this page.
                            http://www.arceurotrade.co.uk/en-gb/dept_175.html
                              Oh, come on John -- Alistair can make one in a couple of hours.
