I am in the process of cleaning up and restoring a double dovetail slide assembly I recently bought on E-Bay. There is a pivot between the two slides and I suspect it was used as a lathe cross slide/compound. It appears to be very well made but shows signs of many years of wear and abuse. Both dovetails are cut at a 45* angle.
My question: when I disassembled the slides for cleaning, I noticed that one of the four jig screws on the lower slide and one of the two screws on the upper slide had a truncated conical tip. The other screws all had completely conical tips. All appear to be originals. Is there a reason for the different kinds of screws?
