I am fixing a leaky seal on my RF-45 mill/drill. The mill is just over a year old. I got inside the gear box and noticed that all the gears are made of wood! Kidding.
All bearings inside the head are sealed. I noticed that one was "dry" and appeared to be toast.
They are SKF brand bearings. Would it be a good idea to remove all the metal seals/covers on one side of the bearings to allow the oil from the head to splash lubricate? The bottom bearings are always in the oil bath, the upper ones are not. It appears the factory grease from other bearings is trying to get out. Maybe the oil I am using is "thinning" out the grease? I am using ISO68, R&O gear oil as prescribed by the good doctor, Thrud.
Any suggestions?
Any suggestions?
