ENP Plating
  • ENP Plating
    Does anyone have any experience with electroless nickle plating, TDC (thin dense chrome), or gullon plating? I would like some opinions beyond that of the vendor. I have concerns about long term adhesion in an abusive environment. The ENP has been suggested for corrosion protection on the inside and outside of a steel part.
    Brownell's www.brownells.com sells the materials and also, I think, has a set of instructions, if that's of any interest. They're also pretty good about answering questions.
    I expect durability depends a lot on how good your surface preparation is and attention to detail during the process.
      ENi is very corrosion resistant. Since it is a chemical process and not electrolytic it plates uniformily on all surfaces exposed to the bath. It is about 52 Rc as plated. You can heat it to about 300 C and it will harden to the equivalent of about 70 Rc. For corrosion protection most ENi is plated about 0.001 inch. Thicker plating takes longer and costs a lot. I recommend having a plater do it and not trying to do it on the kitchen stove. Adhesion to any given substrate is a strong function of pre-conditioning of the part surface. You need to tell the plater the chemical make up of the part material. Good stuff if it is done right.
        Thanks, I was unaware you could do this sort of plating yourself. For these parts however, I will leave it to the professionals.
        I have never heard of ENi, is this another term for ENP?
          ENi is a common description for electroless nickel. Another is NiP for nickel phosphorus. ENi is really a nickel phosphorus alloy and good quality ENi has about 13 percent phosphorus.
            Cass, I notice you are from Rockwall. I am in Mckinney. Perhaps you can recommend a reliable plater in this area?
            Thanks SGW, I found the instructions helpful.
