954 Bronze
  • 954 Bronze
    Could that be used for bearing material instead of 932?
    Extremely low load/speed, etc.
    Len
    copy/paste
    Alloy
    954, aluminium bronze has high
    strength with good impact, wear and
    corrosion resistance, high resistance to
    oxidation and good strength at
    elevated temperatures. Anti-seizure
    properties, however, are poor.
    Typical Applications:
    High strength bearings, bushings, bolts,
    gears, gear wheels, guides, pump rods,
    propellers, pickling hooks, valve seats,
    worm wheels and non-sparking tools etc.
      Pickling hooks as well!?
      And cheaper than 932! Oh, I'm in shape now.
      Thanks mate.
      Len
        Aluminum bronze is very hard. Make sure it's not harder than the parent (sliding) metal.
          660 bronze
          http://www.anchorbronze.com/932stocklist.htm
            Thanks for the link!
            Len
              C923 is a step up from C932 (660) and is used for high-load bearings. It's about the same but has a little less lead. The 923 is also called Navy G-brass. The problem I'm having is finding a place that sells it in shapes other than ingot.
