What is this thing, how is it used?
  • What is this thing, how is it used?
    A friend of mine sent me this picture http://mysite.verizon.net/stockerwel...glevernier.jpg and asked me what the heck it was, how/why was/is it used, and in particular, how does the vernier work. I await your wisdom....
    its for a big gun...the sort thats mounted on wheels
    its used for getting the angles set
    got one myself
    all the best..markj
      Also known as a Clinometer.
      Peter
        Still in use today
        Even on Machine guns....
        Often called a Gunners Quadrant..
        Here is some good info:
        http://browningmgs.com/Clinometer/Clinometer.htm
          Last edited by Hal; 01-30-2008, 06:43 PM. Reason: guessed wrong.........................
            You guys are amazing.
            Any insight as to how the vernier works? It's +/- 25, which is +/- one notch on the angle...but how does sliding the vernier left or right adjust anything?
              'The level holder slides along the curved top surface of the radial arm'
              As it says in the link, the top of the radial arm is curved. And when the level is moved along this curve, the angle changes slightly.
              Thomas
              Problems worthy of attack prove their worth by hitting back
              - Piet Hein
                Thanks - I missed that.
                  Is it safe to say it acts similar to a macninist vernior only for angles?
                    Sight
                    On mortars we used to set the angle and crank until the bubble was centered and level. It was then ready to fire. We were told we were expendable but that mortar sight was not.
                    Chuck
                      Inclinometer
                      Thanks Bguns.
                      A very interesting post.
                      The theory and application of "mil" as applied to the military applications are quite interesting.
                      See the following:
                      http://en.wikipedia.org/wiki/Angular_mil
                      A bit more info on the many uses and applications of inclinometers generally is at:
                      http://en.wikipedia.org/wiki/Inclinometer
                      And yes, I do have a back-ground in military (Naval) guns.
                      Surveying too.
                        That one's from some foreign army, here's a picture of the US version.
                        Joe
                          Range setting
                          The inclinometers shown are calibrated in "mil" - as previously.
                          They are effectively an initial range-setting device.
                          Once the target distance (range) in known, the ballistics tables for the particular weapon and ammunition are consulted to find the gun elevation required in mil units.
                          That is the reason for the spirit level - to set the gun relative to a known zero/horizontal reference.
                          Each gun has its own (in)clinometer which has been set up for/to/on that gun.
                          Once the gun starts firing the aimer uses his vision to determine corrections from the fall of shot for elevation (range) and deflection (left/right).
                          Unless the tribrach on which the gun rotates laterally is very well set up, any errors will negate the range elevation zero at any other bearing.
                          Needless to say, with all the crashing and banging about that the gun gets during firing, it pretty well cancels out further use of the inclinometer.
                          While, in theory, the mil units can be used to set range, the ballistics of the gun and ammunition will require further additional elevation (sometimes called "super-elevation" and other times called "tangent elevation") - as well as "drift".
                          But a good Gunner can estimate range, elevation and drift as can a good rifle-man and adjust accordingly.
                          Now-a-days, "tracer" rounds are included in clips of ammunition to indicate where the fall of shot is.
                          "Spotters" (people) are really excellent here.
                          I suspect that the clinometers would not have got a lot of use when "things got hot".
                            I was on active duty in the US Army for 3 years, Ordnamce Corps and for about 12 more years in the reserves. One of the 3 years of active duty was in Vietnam. Lots of guns of all sizes up to 6 inch/155mm. Frankly, I never saw one of those in use or even in storage. The smaller guns, as in those carried by one man, didn't need it. You aimed and fired or you sprayed with the machine guns. Snipers had scopes. The artillery guns had removable optical "sights" that were a lot more accurate than a gunner's quadrant. These were carefully carried in their own cases and never left on the gun when it was fired. These optical sights were used in conjunction with aiming stakes, not the targets which were completely out of sight.
                            I suspect they are a leftover from the 19th or earlier centuries. Can you say "Civil War"? Today I am sure the aiming technology involves computers and global positioning.
                            Make it fit.
                              Until the late 1950's every artillery piece was supplied with one, a leftover from an earlier era, as you have said. I have never met an artillerist, of any era, that actually used one. Each gun had a flat machined on the breech end parallel with the bore, to place the quadrant on. Probably on the orders of some general that actually remembered using one, back when. The one in the picture has a 7 digit stock number, which makes it pre 1958. I've never seen one newer.
                              Joe
