OT- Taking up old linoleum floor
  • Your Old Dog
    Get one of those narrow trenching spades with a narrow flat blade.
    Sharpen it up with an angle grinder and go to it.
    Not half as much work as with a scraper when you are on your knees.
    I had to rip all the downstairs floors up when wwe move in here and once I had sussed this, it was taking about 3/4 of an hour per room.
    You need one with a tee handle or some form of handle at the top and not a pole type handle.
    they used something like that on the tile floored hallways where I work. The guy slid it along the floor at just less than a 45 degree angle and they flew off. That floor was concrete, don't know how well it would work on wood sturcture.
    John my heart swells with pride in you when you didn't try to tell us you made a shovel like that for Gert to use! You da man John
  • John Stevenson
  • kjbllc
    I was licensed as an asbestos removal, and had to re certified. every year.
    what I learned was, they don't know how much it takes to get sick, they really don't know why some people can be exposed to lots of it and never get it and some people get a little exposure and do. The tiles are very low in asbestos, basically if you keep it wet put it in trash bags, and then double trash bags and goose neck it with duck tape, you are doing the same thing as if they charged you $2,000 to remove it. The dumps here just put it in the same place where the rest of the garbage goes. Some of the more concentrated stuff goes to a special landfill. You can also wear a hepa face mask and use a hepa filter for you vacuum cleaner. Most everyone was exposed to asbestos, in shcools, brake shoes so it still remains a mystery, like cancer itself.
  • Charlie Rose
    My house was built in 1904 the kitchens were redone in about 1950 the tile is the 9" sq. type this is the asbestos tile.If you have 12" sq. tiles you don't have asbestos tiles.
    I and every other shipyard worker was exposed to asbestos before about 1975 or 80 when all the asbestos was removed from the work place.We were placed in an asbestos program and were tested yearly and so far I have no sign of any cancer.The people who smoked were at greater risk from this than a non smoker,however even if you smoked that doesn't mean you will get sick.
    Asbestos was used in all sorts of products such as auto brakes and clutch disks one of the strangest places is in those "popcorn" ceilings that were popular a number of years ago.
    Yep, I was going to mention the fact that the asbestos tile is usually hard..... Breaks, not bends, and gives a little puff of dust when it does (yummy).
    As far as asbestos..... There have been cases of mesoepithelioma (sp?) where the ONLY exposure known was a single weekend installing vermiculite insulation in a poorly ventilated attic. A lot of vermiculite is (or was) contaminated with asbestos.
    That cancer is apparently associated with asbestos, and ONLY asbestos. You get it, you were exposed to asbestos.
    So you do NOT need to have a life-long exposure.
    vinyl floor tile
    The floor tile is not the same as linoleum flooring. The linoleum flooring is a lot more serious.
  • Rich Carlstedt
    DRY ICE, DRY ICE
    the stuff snaps off like pretzels.
    Also "When" they made tile with asbestos in it, it was 9x9.
    12 x 12 tile is Vinyl most likely.
    Does the tile bend at all ?
    Asbestos tile was brittle
    Rich
  • Rustybolt
    I talked to an environmental engineer when I had to remove 2500 sq feet of tile from a shop floor. He said that asbestos remediation of vinyl floor tile is considered a scam. There was actually not a lot of asbestos in the tile and it is encapsulated. The tests for asbestos being a cancer causing substance were taken from asbestos miners who had worked more than 20 years mining the asbestos without protection. there would be the same risk in mining just about anything.
    You risk more stick welding.
    Scape it up, bag it, and send it to the dump.
  • torker
    RW.. it'll still stink with a heat gun just not as bad. I've done what seems to be acres of tile/lino removal in the 40 unit motel we run. To do it right you have to take the old stuff off. I've tried every which way of cheating you can imagine... none of it worked. Now I just grab the ol' heatgun and a long handle thin blade putty knife rig and go at it... inch by agonizing inch.
    Russ
    Just a hunch- it's probable that if you leave whats remaining and level over it, sooner or later it will telegraph through and be ugly. I'd go with the heat gun and just stick it out till it's gone. It won't be as bad as using flame, and as suggested you can always send the wife out for the duration. I would have a constant ventilation going on during the process, and I would probably wet mop a couple times after the job, just to get the loose stuff up. You could maybe vacuum, but you run the risk of raising a toxic dust mixture into the air, not knowing what materials might be there. A built-in vac might be ok, depending on where it exhausts.
    A buddy of mine took up the lino in a bathroom once, and he probably learned a few new four letter words during the many hours it took to do the job.
    Here's one for ya- my house has solid hardwood floors throghout, but is covered mostly by carpet with underlay. In the kitchen and bathroom- guess what- covered by lino. I'd like to bring the original floor back, but I don't even want to start that job.
  • rws
    Yes, it was the smell my wife threw a fit over! Geez, I was on my hands and knees, right over it, and I didn't feel bad. But she came out coughing and hacking like she was poisoned or something.......
    Since I've already taken up 2/3 of the floor, I can't turn back. What I have is that some of the lino came up to the sub-floor, some didn't, about a 50-50.
    So I have two options I think, I have to leave what's there and fill in between for a relatively flat sub-floor, or take up the remainder to the original sub-floor. Either option is a lot of work.
    So, if I go out and get a heat gun, how much "stink" will be given off to loosen the adhesive, as opposed to the propane torch? I just can't see trying to scrape this down without the help of heat. I can get leveling compound and fill in a bunch of spots and areas, then smooth and finish.
    Thanks for the help so far.
  • mikem
    One thing for sure! DO NOT USE gasoline to soften the glue. It is way too flamable. Once saw a guy in the St. Elizabeth Burn Center that tried using it to take up linoleum. A spark ignited the gas and the old guy that had it all over the floor and himself.
    He was crying because his skin grafted and patched arm was stiff and the therapist was making him bend it beyond his comfort level. The next time that I went to see my brother there, the old guy was gone and the nurse said that he had died. NOT WORTH THE RISK!
  • speedsport
    I have one of the $10 HF heatguns, works like a champ.
  • Spin Doctor
    Originally posted by tony ennis
    The asbestos risk for linoleum is very serious. If it is stuck down good, I'd put a new underlayment on top of it and call it a fine day.
    A couple of years ago I was laying new hardwood flooring in my house and when I ripped up the carpeting in the living and dining room I found the floor in the DR had linoleum sheet stock. About the first five or six square feet came up nice and simple. The rest was a royal PITA. The dealer I bought the flooring from when I went in to order some matching registers told me that if I had decided to hire out the install after finding the linoleum and taking part of it up they would of refused the job without a HAZMAT asbestos removal company coming in first. Once you start tearing this stuff out yourself you're stuck doing it yourself. Plus you might have to be sneaky with the disposal.
  • Your Old Dog
    Get everything ready in the garage then send the wife to the other side of town for pizza. When she gets going, you get going and take it out with an axe if necessary. It's easier to get forgiveness then permission as was recently quoted here on the forum.
