small OD copper tubing
  • small OD copper tubing
    Is there copper tubing with OD of ~ 4mm? What is the smallest OD copper tubing available and where can i find some? Im planning on building some heat sinks.
    Refrigeration capillary tubing comes in that and smaller diameters. I've used stuff less than 2.5mm in diameter.
      Most hardware and hobby stores carry the K&S Engineering display. They generally have copper tubing down to 1/16th od by 32nds. 5/32" is .15625 (3.96875 mm).
      Stuart
      Edit: the wall thickness on that tubing is .014" BTW
      Stuart de Haro
        www.smallparts.com has small-diameter tubing.
          copper brake pipe from an auto factors? I think 3/16th is the smallest 'normal' size tho
          Just south of Sudspumpwater UK
            i wonder if home depot has some. what would they call it? im sure the guys working there wont have any idea what im talking about if i ask them for small OD copper tubing..
            thanks in advance
              Hobby shops
              They carry 1/16 copper tube.
              You can also get 1/32 SS tube from Walthers Hobby in Milwaukee
              Rich
              Green Bay, WI
                im looking at multi-hole EDM tubing, has anyone has any experience with this, how expensive is it? (trying to maximize surface area - can either have lots of small tubes or can have bigger tubes that are sub-divided inside)
                  Might look at the therm-o-couple used on gas hot water heaters.it would be close to 4mm
                  Mansfield, Ohio
                    coppertube starting at .010
                    EDM supplies has copper tubing starting at .01 x12 inches long and they have it in .001 steps up to .25
                    800 676-7336
                    Jim
                      thanks everyone! ill try to get some this comming week
