wanted one off pulley
  • wanted one off pulley
    Hi Guys , i`ve been recomended this site as i`m after a pulley for towing radio controlled gliders the basic need is a nylon pulley of approx 90mm diameter and 25mm thick with a vee groove in it to a depth of approx 18mm and a hole in the middle of approx 7mm , i`m UK based so if anyone can help i`d be grateful, many thanks Harvey
    18 mm deep ??
    With a width of 25mm and an angle of 45 degrees this would only work out 12.5 mm deep.
      just measured it accuratly, 77mm diameter 27mm thick and with the vee in it 12mm deep groove ,Harvey
        Just measured the one I just did.
        77mm diameter, 27mm thick with a 12mm deep groove in it and 7mm hole in the centre.
        Email me where you want it sending to.
        john [at] stevenson-engineers.co.uk
          Now what were the chances you would have just made a pulley just like this fellow needed?
          You are a class act, John.
          Paul
          Paul Carpenter
          Mapleton, IL
            This hurts so I'm only going to say it once.
            I have to agree with the above post, you are a class act John....
              /golfclap...
                a true gent,many thanks harvey
                  He's nearly as nice as meAlistair
                    Piss off, no amount of brown hatting will get you a freebie.
                    We are not making porridge for one
                      Glider,
                      John means well but if this thing looks like hell or the dimensions are way off just let me know and I'll get you my address and I'll clean it up for him. I don't mind doing it. Many of us here have had to help him out from time to time when he bites off more than he can chew.
                        Originally posted by Your Old Dog
                        Glider,
                        YOD. Thats the best chuckle I've had all day. :-)
                        ...lew...
                          Glider,
                          Quit YOD, still laughing
