Blake Co-Ax Indicator set up
  • Blake Co-Ax Indicator set up
    Hello all
    I have recently picked up a blake co-ax indicator, and have never used one of these before. I ussumed these would be simple to use, and sure they are but there has to be somthing Im missing.
    I mounted a piece of 1 5/8 round stock to the vise, set up with the curved feeler that the instructions say to use for outside dia to approx 4 1/4 inches.
    The feeler will swing but not the distance to reach around the 1 5/8 stock I want to centre up.
    Is there a ajustment that Im missing here? Is there any sites out there that explain the set-up and use of these indicators? Im not seeing how this thing could sweep around a large dia part.
    There must be somthing Im missing here, can any body help me out here?
    Maybe I got a defect, or I need different feelers, I don,t know.
    Thanks in advance guys
    Paul
    The holder the feeler is inserted in is a friction fit on the rocker arm. It can be moved out to accomodate large diameters, just give it a push.
    Jim H.
      Blake Co-Ax Indicator setup
      Thanks Jim
      Yes, that works perfect. They don,t say anything about that in the instructions. Now it all makes sense .
      Thanks again
      Paul
