Hi All,
Been making chips this weekend both in material and cutters! Busy enlarging the slot in my new QCTP holders when at the end of one cut the cutter grabed the holder, stopped the cutter and blew the fuse to the motor. The y axis was then very sloppy. So I cleaned all the chips cleaned everything and then readjusted the jib strips so all were snug, I then noticed that the gap behing the gib strip was wider than the gib strip itself. I remember in the past that all the lathes I have ever used the gib strip was quite thick and did not have a lot of clearance behind it. I realise that metals are getting scarce but the 1/16 inch strip is a bit penny pinching.
So should the gib strip be quite substantial and fill most of the gap in the slot.
Peter
Peter
